ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
223
Highlighted
Beginner
SSL VPN ISE Posturing within AWS cloud using ASAv
We are looking to move one of our DataCenters to the AWS cloud.  Within this DC we terminate SSL VPNs and posture all of the users as they enter our network.  Is anyone aware if the Virtual ASA's from the Amazon store support ISE posturing?
Appreciate any insight.
Brian
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: SSL VPN ISE Posturing within AWS cloud using ASAv
This would be a question for the asa team but assuming they are running code that supports coa then should work
We have asav for posture in several environments doing posture
Look at table 4 remote access features for coa
http://www.cisco.com/c/en/us/td/docs/security/asa/asa92/release/notes/asarn92.html
1 REPLY 1
