08-09-2017 06:04 AM
Hi all,
Our current deployment: We currently authenticate our AnyConenct users using ISE local accounts via RADIUS.
My question: Is it possible to use SSO integration on the ISE for anyconnect authentication?
The deployment would ideally look like this:
AnyConnect -> ASA -> RADIUS -> ISE -> SAML -> Pingfederate IDP (SSO)
There are ISE guides for network authentication using a portal however not for anyconnect.
Appreciate any help on this.
Solved! Go to Solution.
08-09-2017 06:38 AM
This is on asa and AnyConnect not ise
Please look at saml in the guide
https://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/anyconnect40/administration/guide/b_AnyConnect_Administrator_Guide_4-0/anyconnect-mobile-devices.html
07-18-2018 06:21 PM
As Jason said earlier, it's not possible to do [AnyConnect -> ASA -> RADIUS -> ISE -> SAML -> Pingfederate IDP (SSO)].
Instead, it would be:
AnyConnect -> ASA -> SAML IdP
+----> ISE (could be authorized only).
The configuration would be similar to what discussed in VPN certificate auth using ISE?
08-09-2017 06:38 AM
08-09-2017 06:46 AM
Thought that may be the case. Thanks
07-18-2018 04:39 AM
Looking to do this as well: AnyConnect -> ASA -> RADIUS -> ISE -> SAML -> Pingfederate IDP (SSO). Did you get it working and/or find documentation?
Thanks.
07-18-2018 05:20 AM
Hi Tim sorry we didn't get any further with this, we just kept our current deployment with local accounts on ISE.
I am also unsure if you can use SAML auth with a non mobile, client based Anyconnect if you were to go down the ASA route that Jason mentioned..
07-18-2018 06:21 PM
08-06-2018 11:54 PM
This is possible with Azure AD. But as the colleagues mention, only AnyConnect -> ASA.
If you have multiple factor authentication activated in Azure you can leverage this for your VPN connections when using SAML.
08-15-2018 01:02 PM
You could do the same with ADFS. You could add MFA to the SAML workflow in ADFS then, as has been stated, your authentication would be AnyConnect > ASA > ADFS (with MFA prompting). I think that would work.
I'm working on similar stuff and I use ISE as well.
04-21-2020 09:04 AM
