06-19-2018 02:09 AM
Hie Team
I need help on creating both the policy sets and policy elements on ISE 2.3 for tacacs AAA on Nexus Switches. I can only manage those for the CISCO OS and they are working fine but i cant seem to come across proper information on how to do it for NexusOS as my knowhow in this field is a bit shallow. I kindly need assistance in the step by step configuration on this
Solved! Go to Solution.
06-19-2018 06:17 AM
You don't have to treat the Nexus switches any differently than other Cisco devices if you don't want to. The have privilege level roles built in by default now just like any Cisco device. If you pass back privilege 15 to go to the # prompt directly they will honor that. I usually just set them up as standard Cisco devices with command authorization.
06-19-2018 02:39 AM
06-19-2018 02:51 AM
Thank you. Does this work the same on ISE 2.3 as i have read that 2.3 comes with profile option specifically for NEXUS which i have to use?
06-19-2018 06:17 AM
