TACACS+ Performance question
yongwli
Hi Team,
How many rules is below table based on?
ISE TACACS+ Performance
Platform performance specs are for a dedicated PSN.
PAN and MNT nodes are deployed as separate node(s).
Scenario
Cisco SNS-3415
Appliance
Cisco SNS-3495
Appliance
Cisco SNS-3515
Appliance
Cisco SNS-3595
Appliance
ISE VersionISE 2.0ISE 2.0ISE 2.1ISE 2.1
TACACS+ Function: PAP1,400 / second2,800 / second3,236 / second4,884 / second
TACACS+ Function: CHAP1,500 / second2,900 / second2,413 / second4,961 / second
TACACS+ Function: Enable700 / second1,200 / second1631/second1,984 / second
TACACS+ Function: Session AuthZ900 / second1,700 / second2,191 / second3,453 / second
TACACS+ Function: Command AuthZ900 / second1,700 / second2,359 / second3,467 / second
TACACS+ Function: Accounting2,900 / second4,900 / second3,209 / second9,128 / second
DL
Refer here for policy table limits: ISE Performance & Scale
5 Replies 5
Craig Hyps
Level 10
Level 10
Would require some digging to learn from QA the size of specific rule set used in testing, but I would ask if there is a specific concern over the size of rule set you are using.
Craig
Customer cannot provide policy number at this time, but since they have more than 60K network device, and need to use different condition for different type of network device or location. So policy number will be larger as they said.
Hi Craig,
Customer don't have oversize policies, just need to know the performance number we list based on how many rules. 1 rule or 100 rules? Did you mean the performance number I list in first post is based on max policy number?
DL
Hi DL,
The link below is the same as the one Craig copy/pasted. If you look at the first table, you will see the limits of authentication/ authorization rules per deployment
https://communities.cisco.com/docs/DOC-68347
-Krishnan
