Updated docs on ISE integration with Microsoft Intune?
pglave
Hi all,
I have a customer who is interested in the integration between ISE and Microsoft Intune, for MDM purposes.
So far, I've been able to find in this community post a presentation related to ISE 2.1, written in 2016.
I was wondering if there is any updated documentation that you might know about.
Thank you.
Pier
Francesco Molino
There was a doc published on Microsoft of I recall but based on my experience the doc you're referring to is the most accurate.
I've done few integrations and no doc with deep step by step.
I also forwarded this doc to some customers and this one helped them moving forward.
The config is quite straight forward.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
