08-18-2019 11:11 PM - edited 08-19-2019 03:10 AM
Hello
I am proposing to upgrade a customer's SNS-3595 from ISE 2.2 to ISE 2.4 via the rebuild process ;-) These nodes have some corruption in them and I would feel more comfortable with a complete rebuild. I don't have the luxury to reconfigure from scratch, therefore I will restore config onto the new ISE 2.4 PAN.
I remember an older discussion (I cannot find it) where we debated mounting the .iso media over the network vs via a locally attached USB. I am proposing the USB route because my experience tells me it's WAY WAY faster. Like 8 hours for a network based rebuild, vs 1 hour for USB attached. I have not done this in a while - my number might be off ... if any has done this recently please remind me.
Question 1: Can I re-use the same Base license only the newly installed ISE 2.4 appliance? I don’t deal much with appliances but I suspect the config restore might be able to restore the licenses into a physical appliance??? If not:
If the above is not possible, is the Plan B to re-home the license?
Question 2: How long can I run on 100 endpoint eval in a production network without causing a denial of service? I thought it was around 30 days of license violation that would cause a lockdown to the ISE Licensing Screen?
I am buying myself some time to get the licenses re-homed/sorted but I don't want ISE to degrade the service because customer will be well over the 100 endpoint SUSTAINED usage.
thanks in advance
08-20-2019 07:44 PM
On Q1, CFG restores do not provide valid licenses. So, please re-host the licenses at Cisco Licensing portal.
On Q2, see section 5.1.1 in http://cs.co/ise-licensing. See also How to Get ISE Evaluation Software & Licenses
08-20-2019 08:11 PM
Hello @hslai
thanks for the links - I am struggling with the wording in bold (from the August 2019 Licensing document) :
"Compliance enforcement: The impact described below is experienced after a deployment is out of compliance for 45 out of 60 consecutive days."
I understand it to mean that the compliance is counted over a period of 60 days. Within those 60 days I am allowed 45 days of "non-compliance" before I am jailed into the ISE Licensing Portal Page?
I am unlikely to run into this, but it may take some time to sort out licenses if the customer is busy doing other things.
08-21-2019 01:57 PM
You are correct regarding how the current enforcement works. Today ISE generates alarms if any licenses expiring in > 90 days. With that and the grace period, I hope the customers have enough to renew. Under some exceptional circumstances, the customers may escalate it through their Cisco account teams.
