url web-redirect is not working
apatel2489
i have deployed ISE 2.3 and everythign works fine except client is not getting url redirect page when they open web page on browser.
is there any way that can install manually and doesn't require url redirect. i have copied and paste url from switch port and it worked and compliment but doesn't work automatically.
Ashish
20 Replies 20
Could you please tell me the command that was introduced for the L2 redirection on IOS-XE?  I am changing VLANs for guest clients there is no SVI for the guests in this network.  The clients L3 interface in a firewall outside of the network.
I would recommend you review the information in the guest guide around this
https://community.cisco.com/t5/security-documents/ise-guest-access-prescriptive-deployment-guide/ta-p/3640475
Your answer fixed my issue.
Thank you very much.
Does anyone know why it's necessary to enable the web server for the redirect to work? We want to use redirection in ISE for a quarantine function and be able to redirect user to a "splash page" informing them that their PC is quarantined. However, enabling the web server on the switch is raising security concerns and I am not sure why we need to enable it when we don't use the internal web server. Does it act as a proxy? Anyway to get the re-direction to work without enabling HTTP?
Edit. The following commands makes the switch not allow any sessions, so at least it will prevent unauthorized logins.
ip http secure-active-session-modules none
ip http active-session-modules none
The switch intercepts and does the redirection to the ISE URL. You need something inline to do the redirect. ISE is not inline.
see Configure a Catalyst Switch for Guest Access
