Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
5258
Enthusiast
Re: url web-redirect is not working
Could you please tell me the command that was introduced for the L2 redirection on IOS-XE?  I am changing VLANs for guest clients there is no SVI for the guests in this network.  The clients L3 interface in a firewall outside of the network.
I would recommend you review the information in the guest guide around this
https://community.cisco.com/t5/security-documents/ise-guest-access-prescriptive-deployment-guide/ta-p/3640475
Beginner
Your answer fixed my issue.
Thank you very much.
Beginner
Does anyone know why it's necessary to enable the web server for the redirect to work? We want to use redirection in ISE for a quarantine function and be able to redirect user to a "splash page" informing them that their PC is quarantined. However, enabling the web server on the switch is raising security concerns and I am not sure why we need to enable it when we don't use the internal web server. Does it act as a proxy? Anyway to get the re-direction to work without enabling HTTP?
Edit. The following commands makes the switch not allow any sessions, so at least it will prevent unauthorized logins.
ip http secure-active-session-modules none
ip http active-session-modules none
Highlighted
The switch intercepts and does the redirection to the ISE URL. You need something inline to do the redirect. ISE is not inline.
see Configure a Catalyst Switch for Guest Access
