Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
205
Highlighted
Beginner
Use Cisco ISE as portal with Extreme Network Wireless controller
Hello Community
Are there any documentation about connecting Cisco ISE with Extreme Network Wireless controller?
We want to use Cisco ISE as portal and want to use our Extreme Network Wireless controller.
I'm not sure if this works fine. In some videos, this is configured with the menu item "Wireless Setup" (top right in the ISE). However, a Cisco WLC is always taken.
Can someone help?
Is it possible to use the ISE as a portal with the Extreme Network Wireless controller as WLC?
Marco
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: Use Cisco ISE as portal with Extreme Network Wireless controller
If you have a setup of Extreme Wireless with ISE. I can assist to get it working, please unicast me howon@cisco.com.
4 REPLIES 4
VIP Collaborator
 - Here are some general guidelines :
                https://community.cisco.com/t5/security-documents/does-ise-support-my-network-access-device/ta-p/3650231
 M.
Beginner
Thanks. But this is very general.
I am not sure how does it work with redirect and internet access after accept the Acceptable Use Policy.
We don't offer guidance on configuring all 3rd party. There are some examples here. I would recommend reaching out the extreme as well to see what guidance they have to offer.
Under http://cs.co/ise-guest there are lots of tips/tricks
Also our guide, focuses on cisco equipment - https://community.cisco.com/t5/security-documents/ise-guest-access-prescriptive-deployment-guide/ta-p/3640475
Third party docs:
https://community.cisco.com/t5/security-documents/ise-third-party-nad-profiles-and-configs/ta-p/3648719
Under http://cs.co/ise-guides there are extreme
https://community.cisco.com/t5/security-documents/ise-security-ecosystem-integration-guides/ta-p/3621164#toc-hId--1046905182
Please share your findings and rate this posting
