Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
3145
Highlighted
Beginner
User and Machine Authentication Failure! ISE 2.1
Hey Folks,
I am configuring ISE 2.1, all configuration are done, connectivity to AD is perfect (e.i.PING, deployment status and user verification from External Identity source is fine)
but whenever i am testing the policy, it's not able to pass thru Machine authentication and user authentication. So the current flow is from the default and jumping to posture unknown without passing to machine and user authentication.
Can anyone help me on this please.
1 ACCEPTED SOLUTION
Re: User and Machine Authentication Failure! ISE 2.1
thanks.
about "bypassing any connect scan, your network is configured to use NAC agent"
it can be that the client provisioning doesn't match to rule with  anyconnect configuration...
please below link:
https://supportforums.cisco.com/discussion/12475736/configuration-file-goes-bad-cisco-anyconnect-secure-mobility-client
12 REPLIES 12
Beginner
I am currently using windows 81., do i have to install hotfix or does it need specific patch on ISE 2,1. I already have cisco ISE with patch 1.2.
do you see any errors on live logs?
Can you please post the info you see on live logs page about machine and user authentication ?
Operations>RADIUS >Live logs
Beginner
No, I haven't See any logs about machine and user authentication at all.
it seems that the switch doesn't send the radius request to ISE.
can you  please  post the switch configuration?
Beginner
configuration is applied in port G1/0/5
QYS-GFC-SW#show run
Building configuration...
Current configuration : 27461 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname QYS-GFC-SW
boot-start-marker
boot-end-marker
enable password 7 1531021F07257A767B
--More--                           aaa new-model
aaa group server radius ISE
server 10.10.201.35 auth-port 1812 acct-port 1813
aaa group server tacacs+ ISE_GROUP
server 10.10.201.35
server-private 10.10.201.35 key 7 104D000A0618
aaa authentication login TAC local
aaa authentication login NO-AUTHIN none
aaa authentication login AAA group ISE_GROUP local
aaa authentication enable default group ISE_GROUP enable
aaa authentication dot1x default group ISE
aaa authorization config-commands
aaa authorization exec AAA group ISE_GROUP local
aaa authorization commands 0 AAA group ISE_GROUP local
aaa authorization commands 1 AAA group ISE_GROUP local
aaa authorization commands 15 AAA group ISE_GROUP local
aaa authorization network default group ISE
aaa authorization auth-proxy default group ISE
aaa accounting delay-start all
--More--                           aaa accounting auth-proxy default start-stop group ISE
aaa accounting dot1x default start-stop group ISE
aaa accounting exec default start-stop group ISE_GROUP
aaa accounting commands 1 default start-stop group ISE_GROUP
aaa accounting commands 15 default start-stop group ISE_GROUP
aaa accounting network default start-stop group ISE
aaa server radius dynamic-author
client 10.10.201.35 server-key 7 132C2437021F277A7B08
aaa session-id common
clock timezone UTC 3
switch 1 provision ws-c3750g-48ps
system mtu routing 1500
ip domain-name qyias.org
ip dhcp snooping
ip device tracking
login block-for 1 attempts 3 within 5
login on-failure log
login on-success log
--More--                           !
crypto pki trustpoint TP-self-signed-2786833280
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2786833280
revocation-check none
rsakeypair TP-self-signed-2786833280
crypto pki certificate chain TP-self-signed-2786833280
certificate self-signed 01
  3082024C 308201B5 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32373836 38333332 3830301E 170D3933 30333031 30303034
  32355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37383638
  33333238 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C928 6BB575DA 11BD2DA1 77D9C56A D5B282A6 F102E972 38BA5A3E 0E28672F
  4BEB9E63 96DBD812 7861BB54 9F9A411C 65BC3727 FD5499D6 A626B1AD A926469F
  CDF49990 CA2D1A31 5FE1EE0D 8EC4556C BB85D0BD 180EA696 30A8A09A 8003F2F0
  DDA3D872 8C26F374 22E87EDF 5EEF05B2 3E7453CF 354937FC 6D02744D B1D4610A
  EB870203 010001A3 74307230 0F060355 1D130101 FF040530 030101FF 301F0603
  551D1104 18301682 14515953 2D474643 2D53572E 71796961 732E6F72 67301F06
--More--                             03551D23 04183016 80148B0B 81DFDAF8 0D1F4C20 C941D92E C3450841 E357301D
  0603551D 0E041604 148B0B81 DFDAF80D 1F4C20C9 41D92EC3 450841E3 57300D06
  092A8648 86F70D01 01040500 03818100 B24144E5 23C7DB88 02E39983 2D9ADE32
  B877FE28 2BC1EB37 A3A155FA A5A26F0F 5F32327D 12C6FB68 9E470D95 B8170720
  5DCC765D 88ACA3D9 18DCEBC9 CA0B1FCF 70DC7870 BA1C8F3D 949135DD 452D8EB1
  DD61D621 8D7246C4 EF06C0F6 5FBCC823 731916DE 1AFE709D 7D842562 6C88810E
  24E324DA 48ED34C3 A5EAA8D8 BAF207AF
  quit
dot1x system-auth-control
dot1x critical eapol
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh version 2
interface Port-channel2
--More--                            description "GFC-SW to DES-SW"
switchport trunk native vlan 251
switchport mode trunk
interface GigabitEthernet1/0/1
switchport access vlan 10
switchport mode access
switchport voice vlan 110
switchport port-security maximum 2
switchport port-security violation restrict
switchport port-security mac-address sticky
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/0/2
--More--                            switchport port-security mac-address sticky
interface GigabitEthernet1/0/3
switchport port-security mac-address sticky c81f.66aa.91d3 vlan access
switchport port-security mac-address sticky ece1.a985.a05a vlan voice
interface GigabitEthernet1/0/4
--More--                            switchport port-security violation restrict
interface GigabitEthernet1/0/5
authentication event fail action next-method
authentication event server dead action authorize vlan 10
authentication event server alive action reinitialize
authentication host-mode multi-domain
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
authentication violation restrict
mab
mls qos trust device cisco-phone
mls qos trust cos
snmp trap mac-notification change added
--More--                            dot1x pae authenticator
dot1x timeout tx-period 10
interface GigabitEthernet1/0/6
switchport port-security mac-address sticky f48e.387e.5998 vlan access
switchport port-security mac-address sticky 04c5.a44d.b1d1 vlan voice
interface GigabitEthernet1/0/48
--More--                           interface GigabitEthernet1/0/49
channel-group 2 mode active
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
no ip address
shutdown
interface Vlan251
ip address 10.10.251.70 255.255.255.0
--More--                           ip default-gateway 10.10.251.1
ip classless
ip http server
ip http secure-server
ip access-list extended redirection
remark DNS and DHCP
deny   udp any eq bootpc any
deny   udp any any eq bootps
deny   udp any any eq domain
deny   icmp any any echo-reply
remark RDP
deny   tcp any any eq 3389
remark ISE nodes
deny   ip any host 10.10.201.35
remark DC nodes
deny   ip any host 10.10.175.10
deny   ip any host 10.10.175.11
remark AV nodes
deny   ip any host 10.10.155.10
remark windows update server
deny   ip any host 10.10.200.16
--More--                            remark redirect-all-other-traffic
permit ip any any
ip radius source-interface Vlan251
logging trap debugging
logging origin-id ip
logging facility syslog
logging source-interface Vlan251
logging 10.10.200.15
logging 10.10.200.20
logging host 10.10.201.35 transport udp port 20514
access-list 20 permit 10.10.201.35
snmp-server community QYS@CW RO 20
snmp-server trap-source Vlan251
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps cluster
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps power-ethernet group 1-9
snmp-server enable traps vtp
--More--                           snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps stackwise
snmp-server enable traps license
snmp-server enable traps config-copy
snmp-server enable traps hsrp
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps rtr
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
snmp-server host 10.10.200.15 informs version 2c QYS@CW
snmp-server host 10.10.200.26 informs version 2c QYS@CW
snmp-server host 10.10.200.15 version 2c QYS@CW
snmp-server host 10.10.200.26 version 2c QYS@CW
snmp-server host 10.10.201.35 version 2c QYS@CW  mac-notification snmp
tacacs-server host 10.10.201.35
--More--                           tacacs-server directed-request
tacacs-server key 7 13061E010803
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 5 tries 2
radius-server host 10.10.201.35 auth-port 1812 acct-port 1813 key 7 132C2437021F277A7B08
radius-server timeout 3
radius-server deadtime 10
radius-server vsa send accounting
radius-server vsa send authentication
end
Beginner
ONLY machine and user authentication is not found in ISE, but other policy like Posture unknown logs can be found in ISE.
thanks.
Can you please
1. enable debug radius on switch  ( "debug radius")
2. disable and enable the NIC on windows 8.1
3. copy the output to file and send us.
please post the output of  'show authentication session int  g1/0/5'  also.
thanks.
Beginner
Thanks, Here is the debug output...
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2017.04.02 14:15:40 =~=~=~=~=~=~=~=~=~=~=~=
debu
QYS-GFC-SW#debug a   radius
QYS-GFC-SW#debug radius authen
QYS-GFC-SW#debug radius authentication
Radius protocol debugging is on
Radius protocol brief debugging is off
Radius protocol verbose debugging is off
Radius packet hex dump debugging is off
Radius packet protocol (authentication) debugging is on
Radius packet protocol (accounting) debugging is off
Radius packet retransmission debugging is off
Radius server fail-over debugging is off
Radius elog debugging is off
QYS-GFC-SW#term mon
QYS-GFC-SW#
QYS-GFC-SW#
47w0d: %AUTHMGR-5-START: Starting 'dot1x' for client (ecf4.bb7d.cb15) on Interface Gi1/0/5 AuditSessionID 0A0AFB46000000BF9EDE5F06
47w0d: %AUTHMGR-5-START: Starting 'dot1x' for client (ecf4.bb7d.cb15) on Interface Gi1/0/5 AuditSessionID 0A0AFB46000000C09EDE6067
47w0d: RADIUS/ENCODE(00000202):Orig. component type = DOT1X
47w0d: RADIUS(00000202): Config NAS IP: 10.10.251.70
47w0d: RADIUS/ENCODE(00000202): acct_session_id: 755
47w0d: RADIUS(00000202): sending
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/36, len 212
47w0d: RADIUS:  authenticator A5 57 55 E6 E0 F6 C2 6F - 97 C6 92 71 30 9E 77 80
47w0d: RADIUS:  User-Name           [1]   11  "anonymous"
47w0d: RADIUS:  Service-Type        [6]   6   Framed                    [2]
47w0d: RADIUS:  Framed-IP-Address   [8]   6   10.10.10.70
47w0d: RADIUS:  Framed-MTU          [12]  6   1500
47w0d: RADIUS:  Called-Station-Id   [30]  19  "30-37-A6-1B-B3-85"
47w0d: RADIUS:  Calling-Station-Id  [31]  19  "EC-F4-BB-7D-CB-15"
47w0d: RADIUS:  EAP-Message         [79]  16
47w0d: RADIUS:   02 01 00 0E 01 61 6E 6F 6E 79 6D 6F 75 73         [ anonymous]
47w0d: RADIUS:  Message-Authenticato[80]  18
47w0d: RADIUS:   ED 59 5B 79 5F E8 46 7F E6 83 C9 61 BF 89 66 C3           [ Y[y_Faf]
47w0d: RADIUS:  EAP-Key-Name        [102] 2   *
47w0d: RADIUS:  Vendor, Cisco       [26]  49
47w0d: RADIUS:   Cisco AVpair       [1]   43  "audit-session-id=0A0AFB46000000C09EDE6067"
47w0d: RADIUS:  NAS-Port-Type       [61]  6   Ethernet                  [15]
47w0d: RADIUS:  NAS-Port            [5]   6   50105
47w0d: RADIUS:  NAS-Port-Id         [87]  22  "GigabitEthernet1/0/5"
47w0d: RADIUS:  NAS-IP-Address      [4]   6   10.10.251.70
47w0d: RADIUS(00000202): Started 3 sec timeout
47w0d: RADIUS: Received from id 1645/36 10.10.201.35:1812, Access-Challenge, len 145
47w0d: RADIUS:  authenticator B0 E0 A9 48 B2 4E E1 87 - 5A 32 01 6B 42 EF 8D 08
47w0d: RADIUS:  State               [24]  79
47w0d: RADIUS:   33 37 43 50 4D 53 65 73 73 69 6F 6E 49 44 3D 30  [37CPMSessionID=0]
47w0d: RADIUS:   41 30 41 46 42 34 36 30 30 30 30 30 30 43 30 39  [A0AFB46000000C09]
47w0d: RADIUS:   45 44 45 36 30 36 37 3B 33 34 53 65 73 73 69 6F  [EDE6067;34Sessio]
47w0d: RADIUS:   6E 49 44 3D 51 49 53 52 49 53 45 30 31 2F 32 38  [nID=QISRISE01/28]
47w0d: RADIUS:   30 34 39 35 35 37 36 2F 32 30 36 32 3B     [ 0495576/2062;]
47w0d: RADIUS:  EAP-Message         [79]  28
47w0d: RADIUS:   01 BD 00 1A 2B 21 00 04 00 10 99 F1 1A C8 CF AB D4 DE 28 0D 01 41 E2 43 98 7B            [ +!(AC{]
47w0d: RADIUS:   17 67 7B 5C C2 C1 E4 9F 13 A2 29 CC 75 98 98 73            [ g{\)us]
47w0d: RADIUS(00000202): Received from id 1645/36
47w0d: RADIUS/DECODE: EAP-Message fragments, 26, total 26 bytes
47w0d: RADIUS/ENCODE: EAP-Message fragment 288 into 253+35, total 288 bytes
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/37, len 567
47w0d: RADIUS:  authenticator 69 43 40 06 B2 80 2D 87 - 95 84 27 6D 64 46 2A FE
47w0d: RADIUS:  EAP-Message         [79]  255
47w0d: RADIUS:   02 BD 01 20 2B 01 16 03 01 01 15 01 00 01 11 03 01 F8 0D 81 24 10 5E 6B A1 42 FD 39 BD DC 3B 4A A4 CD 92 03 72 A4 E2 7D 1A 6B E7 27 11 57 BC F5 A7 00 00 1A C0 14 C0 0A 00 39 00 35  [ +$^kB9;Jr}k'W95]
47w0d: RADIUS:   C0 13 C0 09 00 33 00 2F C0 12 C0 08 00 16 00 0A 00 FF 01 00 00 CE 00 23 00 B4 00 02 00 B0 00 03 00 01 00 04 00 10 99 F1 1A C8 CF AB D4 DE 28 0D 01 41 E2 43 98 7B 00 06 00 94 00 03 01 00 F4 24 88 8C 8C 9E B9 7B 3D 1C E7 EC 3A E2 EB 7E 00 00 00 13 58 DA 25 25 00 09 3A  [3/#(AC{${=:~X??:]
47w0d: RADIUS:   80 3F A0 48 D9 87 B3 E6 00 A6 A0 A1 88 3F 37 12 B4 F9 4F B0 60 E2 15 1B E0 27 5C 37 1D 46 5D C0 8A EA 02 3E 5F 19 60 1A ED 96 E4 5F 73  [?H?7O`'\7F]>_`_s]
47w0d: RADIUS:   04 33 AD EA 87 8B 51 F6 29 06 66 EC B6 FD 4C 40 6F 25 A5 68 B6 BA B9 0A EF BB 93 D2 A0 22 62 6A 51 2E C4 D8 E2 AB AA A1 84 44 58  [3Q)fL@o?h"bjQ.DX]
47w0d: RADIUS:   EE 2B 05 AF 32 D0 54 2D A0 73 3E DD D8 F5 2C A8           [ +2T-s>,]
47w0d: RADIUS:  EAP-Message         [79]  37
47w0d: RADIUS:   F4 74 B0 6F 0C DC 98 3C 03 6F 69 35 43 00 0B 00 04 03 00 01 02 00 0A 00 0A 00 08 00 19 00 18 00 17 00 13           [ to<oi5C]
47w0d: RADIUS:   1F 74 77 C7 D9 BD C1 AB C0 EC E9 EB 53 00 56 C6              [ twSV]
47w0d: RADIUS: Received from id 1645/37 10.10.201.35:1812, Access-Challenge, len 273
47w0d: RADIUS:  authenticator 34 D2 3A 78 F1 8D 51 2E - D9 FC FE 3A 14 62 32 F5
47w0d: RADIUS:  EAP-Message         [79]  156
47w0d: RADIUS:   01 BE 00 9A 2B 01 16 03 01 00 54 02 00 00 50 03 01 C2 74 D9 30 AC 7B 6C B9 67 90 EC 9E A3 70 35 28 B0 5E 5B 64 4D 8E F0 58  [+TPt0{lgp5(^[dMX]
47w0d: RADIUS:   67 A9 BA 81 C9 42 AC EC 20 DE E4 5C F7 6A A8 E4 8A 9F 05 DA 25 B0 D3 81 0A 9A E7 EF 7F 8B 3F 3D 42 27 8A E2 C8 3C 91 88 AE C0 14 00 00 08 00 0B 00 04 03 00 01 02 14 03 01 00 01 01 16 03 01 00 30 E1 19 9D D3 B7 87 94 62 A0 FC 44 44 6C  [gB \j??=B'<0bDDl]
47w0d: RADIUS:   BD 4D D6 E8 6B 32 8A 61 52 E4 DD B6 CC 17 D0 7B DB 4C 18 F1 F1 8E E3 51 EA 13 59 6B 1F 9B F1 01 F2 67 A7       [ Mk2aR{LQYkg]
47w0d: RADIUS:   99 F4 EA 12 B9 07 0E 06 2D 54 93 C9 8E 8D 02 BE                [ -T]
47w0d: RADIUS(00000202): Received from id 1645/37
47w0d: RADIUS/DECODE: EAP-Message fragments, 154, total 154 bytes
47w0d: RADIUS/ENCODE: EAP-Message fragment 699 into 253+253+193, total 699 bytes
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/38, len 980
47w0d: RADIUS:  authenticator E5 9F 4D 6C ED 1E 7D F2 - B3 09 96 B3 8E A0 28 A4
47w0d: RADIUS:   02 BE 02 BB 2B 01 14 03 01 00 01 01 16 03 01 00 30 04 10 CE 80 97 64 F7 BC 39 75 5C 24 27 F9 96 31 F1 D0 99 AA E1 F3 47 43 15 E9 09 E8 14 F7 C1 58 7C DB D5 26 A3 3F 6E  [+0d9u\$'1GCX|&?n]
47w0d: RADIUS:   5C 82 BE E1 AD 49 0C CB 41 17 03 01 00 20 08 47 02 AD 11 1F 0E E4 26 86 BA 2B 4D 9C 76 C8 86 4D D3 37 C1 21 D7 1F A0 D4 60 66 3D E1 36  [\IA G&+MvM7!`f=6]
47w0d: RADIUS:   26 17 03 01 02 50 D2 70 08 64 C9 87 90 E1 4F 0D FB 85 94 5F DE 43 1A 4C BB 60 1C EC 38 0C A3 88 D4 D3 57 0B 54 87 09 9A C5 E2 E8 28 E3 F8 7D 8F 56 1F E7 33  [&PpdO_CL`8WT(}V3]
47w0d: RADIUS:   BF 3E ED 9F 6F 5A 34 30 FD 06 69 93 CD 4A 2B 63 72 D5 91 7C 62 8E 42 B1 2B 5E 55  [>oZ40iJ+cr|bB+^U]
47w0d: RADIUS:   3F 3A FB B7 A4 F5 3E DE 16 EF 47 50 47 75 99 A5 A1 89 18 02 AE 7E AB 32 9E 50 8E 45 7F 92 81 21 36 50 16 E8 1D 4B 9E 55  [?:>GPGu~2PE!6PKU]
47w0d: RADIUS:   85 2C A5 94 A0 6D A0 58 86 1E 98 39 56 92 A8 AD CC 55 43 84 8E CB 9B DE A6 47 3E 39 E5 46 C4 FC 89       [ ,mX9VUCG>9F]
47w0d: RADIUS:   E2 A1 A4 9E D1 A3 60 E4 AB 86 E9 DD 54 19 38 8E E4 21 DF 15 29 7B BE BA C0 33 28 8C AB 08 84 F3 B6 E3 5C 91 C9 7E 46 02 D0 FA 8A 71 C2 2D BF CA 89 4B 56 F0 9A B7 69  [`T8!){3(\~Fq-KVi]
47w0d: RADIUS:   78 DA A6 28 0E B1 97 1A CE 4D 94 B2 AF A6 91 12 3F 2A 41 72 1B 06 3B D9 07 50 97 38 98 22 14 16 E2 B2 8B F2 78 71 4D E2 84 DE 9F 3A C9 C8 FE A2 B6 9D 13 E9 0A 13 DB F0 0C 01 CC 36  [x(M?*Ar;P8"xqM:6]
47w0d: RADIUS:   A9 56 10 4B F2 24 C0 EF FA FD F7 11 21 82 5C F7 82 88 9A 0C 32 10 E9 F5 E4 DC 0F AF B5 C8 81 D6 C5 16 7C C3 31 C8 08 C9 4C D6 E7 AD 0A 8D 45 75 CA F1 B9 14 62 81 79 11 74 CD E7 88 38 88 A9 E6 14 5D  [VK$!\2|1LEubyt8]]
47w0d: RADIUS:   9F 20 2C 73 89 09 91 EE A8 21 63 2A 68 9D 8A E4 A6 A6 D7 59 FB 9C A6 C8 67 E1 71 D9 48 DF 13 0D 20 D1 87 A4 58 F1 B9 5C 1B 3B 00 56  [ ,s!c*hYgqH X\;V]
47w0d: RADIUS:   CA EF 72 E0 36 0D 23 B9 77 F2 B5 19 7E 6B 6F 36 7D 2F 18 0C 45 D0 0E 29 63 0C B8 49    [ r6#w~ko6}/E)cI]
47w0d: RADIUS:  EAP-Message         [79]  195
47w0d: RADIUS:   ED FB 02 9F 12 25 91 8B EB F8 A2 3A 33 5C 6D FC 03 A8 F5 A2 1D 54 1F 20 0D 1C 60 8D D0 6C 95 4A 5E 8A B4 0B 16 92 81 C6 CA 63 D1 25 48 A0 D9 1D C1 CB 36 D7 84 71  [?:3\mT `lJ^c?H6q]
47w0d: RADIUS:   B8 3F C0 82 28 4E 52 05 3D 7D E5 5F 9B 0F 08 EA 18 A8 E6 21 A3 A4 C8 53 43 BF 74 6C EC 56 F7 87 C8 A8 58 2E D5 12 45  [?(NR=}_!SCtlVX.E]
47w0d: RADIUS:   F7 D1 D2 BF 95 92 83 10 08 BF FD 9A 83 66 2B 67 C1 6F 7D 54 5B 10 48 B2 D0 ED 73 D5 13 59 0A 0F D1 05 42 08 F4 5B CB 62 EF C8 E2 58 1F 43 03 41  [f+go}T[HsYB[bXCA]
47w0d: RADIUS:   7D BA BD 47 A2 38 58 20 02 80 7D 73 99 03 AE C6 C2 A1 C5 D7 8C 49 1E 31 B9 79 DD EF 4B 52 61 15 1A 4F D6 FC 1D 1B 0E 28 43  [}G8X }sI1yKRaO(C]
47w0d: RADIUS:   11 7C E6 48 61 66 26 16 6A 64 A1           [ |Haf&jd]
47w0d: RADIUS:   26 CB D4 4A AC 0C BB F3 EC BC BC 0F F0 1A D3 9F                [ &J]
47w0d: RADIUS: Received from id 1645/38 10.10.201.35:1812, Access-Challenge, len 162
47w0d: RADIUS:  authenticator B4 8B EF F9 3D CA F7 BB - 65 F8 05 69 5B 2C 80 D6
47w0d: RADIUS:  EAP-Message         [79]  45
47w0d: RADIUS:   01 BF 00 2B 2B 01 17 03 01 00 20 70 11 3B D9 BB 6C DE F2 41 64 1E 79 D4 09 24 0D A9 3B D5 12 DD DD B2 C7 5C FA 6D 25 C5 0C 03 3E   [ ++ p;lAdy$;\m?>]
47w0d: RADIUS:   86 ED AD A7 AE D3 F1 45 4A E2 65 EA 17 39 07 64             [ EJe9d]
47w0d: RADIUS(00000202): Received from id 1645/38
47w0d: RADIUS/DECODE: EAP-Message fragments, 43, total 43 bytes
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/39, len 357
47w0d: RADIUS:  authenticator 76 24 AC 2E 50 3A C8 B1 - 32 E8 7B 5F 5F 97 FE 25
47w0d: RADIUS:  EAP-Message         [79]  82
47w0d: RADIUS:   02 BF 00 50 2B 01 17 03 01 00 20 4D 3D C0 3A CE 71 28 39 56 41 B3 11 A5 C1 31 38 5E 7E 03 11 FA BB EE 63  [P+ M=:q(9VA18^~c]
47w0d: RADIUS:   99 2A A2 FD 36 3F 47 1A 17 03 01 00 20 6A 80 A5 51 99 09 5A 8A CD B2 05 4D C3 BB C8 7E 23 5E 53 EB 9F 9A 52 5D 0F 02 EB DF 6E  [*6?G jQZM~#^SR]n]
47w0d: RADIUS:   7E 66 27               [ ~f']
47w0d: RADIUS:   E4 7F 74 71 EF 4C D2 CA 09 11 0F 6F A5 9A 0D 8C              [ tqLo]
47w0d: RADIUS: Received from id 1645/39 10.10.201.35:1812, Access-Accept, len 684
47w0d: RADIUS:  authenticator B1 9C FA 0B 26 EB 84 5B - 08 A5 64 FA 5A C0 A2 DE
47w0d: RADIUS:  User-Name           [1]   6   "ise1"
47w0d: RADIUS:  State               [24]  40
47w0d: RADIUS:   52 65 61 75 74 68 53 65 73 73 69 6F 6E 3A 30 41  [ReauthSession:0A]
47w0d: RADIUS:   30 41 46 42 34 36 30 30 30 30 30 30 43 30 39 45  [0AFB46000000C09E]
47w0d: RADIUS:   44 45 36 30 36 37            [ DE6067]
47w0d: RADIUS:  Class               [25]  56
47w0d: RADIUS:   43 41 43 53 3A 30 41 30 41 46 42 34 36 30 30 30  [CACS:0A0AFB46000]
47w0d: RADIUS:   30 30 30 43 30 39 45 44 45 36 30 36 37 3A 51 49  [000C09EDE6067:QI]
47w0d: RADIUS:   53 52 49 53 45 30 31 2F 32 38 30 34 39 35 35 37  [SRISE01/28049557]
47w0d: RADIUS:   36 2F 32 30 36 32            [ 6/2062]
47w0d: RADIUS:  EAP-Message         [79]  6
47w0d: RADIUS:   03 BF 00 04
47w0d: RADIUS:   E0 44 D1 1A 56 A0 4B F9 81 AF E4 81 4E B9 19 06              [ DVKN]
47w0d: RADIUS:  EAP-Key-Name        [102] 67  *
47w0d: RADIUS:  Vendor, Cisco       [26]  36
47w0d: RADIUS:   Cisco AVpair       [1]   30  "url-redirect-acl=redirection"
47w0d: RADIUS:  Vendor, Cisco       [26]  190
47w0d: RADIUS:   Cisco AVpair       [1]   184 "url-redirect=https://10.10.201.35:8443/portal/gateway?sessionId=0A0AFB46000000C09EDE6067&portal=a6bb0db0-2230-11e6-99ab-005056bf55e0&action=cpp&token=32af2a9b2c8c64687b54f573c5650431"
47w0d: RADIUS:  Vendor, Cisco       [26]  97
47w0d: RADIUS:   Cisco AVpair       [1]   91  "ACS:CiscoSecure-Defined-ACL=#ACSACL#-IP-Qiyas_Swithches_Employee_Posture_Unknown-58c660dd"
47w0d: RADIUS:  Vendor, Cisco       [26]  32
47w0d: RADIUS:   Cisco AVpair       [1]   26  "profile-name=Dell-Device"
47w0d: RADIUS:  Vendor, Microsoft   [26]  58
47w0d: RADIUS:   MS-MPPE-Send-Key   [16]  52  *
47w0d: RADIUS:   MS-MPPE-Recv-Key   [17]  52  *
47w0d: RADIUS(00000202): Received from id 1645/39
47w0d: RADIUS/DECODE: EAP-Message fragments, 4, total 4 bytes
47w0d: RADIUS/DECODE: parse unknown cisco vsa "profile-name" - IGNORE
47w0d: %DOT1X-5-SUCCESS: Authentication successful for client (ecf4.bb7d.cb15) on Interface Gi1/0/5 AuditSessionID
47w0d: %AUTHMGR-7-RESULT: Authentication result 'success' from 'dot1x' for client (ecf4.bb7d.cb15) on Interface Gi1/0/5 AuditSessionID 0A0AFB46000000C09EDE6067
47w0d: RADIUS/ENCODE(00000000):Orig. component type = INVALID
47w0d: RADIUS(00000000): Config NAS IP: 10.10.251.70
47w0d: RADIUS(00000000): sending
47w0d: RADIUS(00000000): Send Access-Request to 10.10.201.35:1812 id 1645/40, len 169
47w0d: RADIUS:  authenticator EB 46 D0 20 69 30 D4 AF - C9 F3 1F 8E D3 B8 36 7C
47w0d: RADIUS:  User-Name           [1]   63  "#ACSACL#-IP-Qiyas_Swithches_Employee_Posture_Unknown-58c660dd"
47w0d: RADIUS:   Cisco AVpair       [1]   26  "aaa:service=ip_admission"
47w0d: RADIUS:  Vendor, Cisco       [26]  30
47w0d: RADIUS:   Cisco AVpair       [1]   24  "aaa:event=acl-download"
47w0d: RADIUS:   7B DC 59 A4 8B C5 B9 E9 62 C3 4F 0A CA 5F 1D DB             [ {YbO_]
47w0d: RADIUS(00000000): Started 3 sec timeout
47w0d: RADIUS: Received from id 1645/40 10.10.201.35:1812, Access-Accept, len 1051
47w0d: RADIUS:  authenticator A0 DA 52 5D A3 BA 5A 9D - 4C D7 44 85 9F 9C 11 2A
47w0d: RADIUS:  State               [24]  67
47w0d: RADIUS:   52 65 61 75 74 68 53 65 73 73 69 6F 6E 3A 30 61  [ReauthSession:0a]
47w0d: RADIUS:   30 61 63 39 32 33 42 37 46 39 50 47 57 52 51 75  [0ac923B7F9PGWRQu]
47w0d: RADIUS:   6A 68 4E 39 57 56 4C 68 78 64 43 46 4D 52 67 6F  [jhN9WVLhxdCFMRgo]
47w0d: RADIUS:   72 6D 61 2F 47 7A 56 4C 6F 32 2F 54 6F 65 44 54  [rma/GzVLo2/ToeDT]
47w0d: RADIUS:   38                 [ 8]
47w0d: RADIUS:  Class               [25]  83
47w0d: RADIUS:   43 41 43 53 3A 30 61 30 61 63 39 32 33 42 37 46  [CACS:0a0ac923B7F]
47w0d: RADIUS:   39 50 47 57 52 51 75 6A 68 4E 39 57 56 4C 68 78  [9PGWRQujhN9WVLhx]
47w0d: RADIUS:   64 43 46 4D 52 67 6F 72 6D 61 2F 47 7A 56 4C 6F  [dCFMRgorma/GzVLo]
47w0d: RADIUS:   32 2F 54 6F 65 44 54 38 3A 51 49 53 52 49 53 45  [2/ToeDT8:QISRISE]
47w0d: RADIUS:   30 31 2F 32 38 30 34 39 35 35 37 36 2F 32 30 36  [01/280495576/206]
47w0d: RADIUS:   33                 [ 3]
47w0d: RADIUS:   24 5E 6E 13 90 72 50 F4 7C B0 01 97 98 E9 FA 1E            [ $^nrP|]
47w0d: RADIUS:  Vendor, Cisco       [26]  38
47w0d: RADIUS:   Cisco AVpair       [1]   32  "ip:inacl#1=Remark DHCP and DNS"
47w0d: RADIUS:  Vendor, Cisco       [26]  47
47w0d: RADIUS:   Cisco AVpair       [1]   41  "ip:inacl#2=permit udp any eq bootpc any"
47w0d: RADIUS:  Vendor, Cisco       [26]  48
47w0d: RADIUS:   Cisco AVpair       [1]   42  "ip:inacl#3=permit udp any any eq bootps "
47w0d: RADIUS:  Vendor, Cisco       [26]  43
47w0d: RADIUS:   Cisco AVpair       [1]   37  "ip:inacl#4=permit udp any any eq 53"
47w0d: RADIUS:  Vendor, Cisco       [26]  34
47w0d: RADIUS:   Cisco AVpair       [1]   28  "ip:inacl#5=Remark ISE Node"
47w0d: RADIUS:  Vendor, Cisco       [26]  50
47w0d: RADIUS:   Cisco AVpair       [1]   44  "ip:inacl#6=permit ip any host 10.10.201.35"
47w0d: RADIUS:   Cisco AVpair       [1]   30  "ip:inacl#7=Remark AD Servers"
47w0d: RADIUS:   Cisco AVpair       [1]   44  "ip:inacl#8=permit ip any host 10.10.175.10"
47w0d: RADIUS:   Cisco AVpair       [1]   44  "ip:inacl#9=permit ip any host 10.10.175.11"
47w0d: RADIUS:  Vendor, Cisco       [26]  44
47w0d: RADIUS:   Cisco AVpair       [1]   38  "ip:inacl#10=Remark Anti Virus Server"
47w0d: RADIUS:  Vendor, Cisco       [26]  51
47w0d: RADIUS:   Cisco AVpair       [1]   45  "ip:inacl#11=permit ip any host 10.10.155.10"
47w0d: RADIUS:   Cisco AVpair       [1]   43  "ip:inacl#12=Remark Windows Update Servers"
47w0d: RADIUS:   Cisco AVpair       [1]   45  "ip:inacl#13=permit ip any host 10.10.200.16"
47w0d: RADIUS:   Cisco AVpair       [1]   32  "ip:inacl#14=Remark Allow Ping "
47w0d: RADIUS:   Cisco AVpair       [1]   38  "ip:inacl#15=permit icmp any any echo"
47w0d: RADIUS:   Cisco AVpair       [1]   44  "ip:inacl#16=permit icmp any any echo-reply"
47w0d: RADIUS:  Vendor, Cisco       [26]  31
47w0d: RADIUS:   Cisco AVpair       [1]   25  "ip:inacl#17=Remark RDP "
47w0d: RADIUS:  Vendor, Cisco       [26]  46
47w0d: RADIUS:   Cisco AVpair       [1]   40  "ip:inacl#18=permit tcp any eq 3389 any"
47w0d: RADIUS(00000000): Received from id 1645/40
47w0d: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (ecf4.bb7d.cb15) on Interface Gi1/0/5 AuditSessionID 0A0AFB46000000C09EDE6067
47w0d: RADIUS: Received from id 1646/82 10.10.201.35:1813, Accounting-response, len 20
47w0d: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5, changed state to up
47w0d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up
47w0d: RADIUS: COA  received from id 72 10.10.201.35:31697, CoA Request, len 224
47w0d: RADIUS/DECODE: parse unknown cisco vsa "reauthenticate-type" - IGNORE
47w0d: RADIUS(00000000): Send CoA Ack Response to 10.10.201.35:31697 id 72, len 20
47w0d: RADIUS:  authenticator 61 AB F4 62 82 B5 2A AF - 99 7D C7 58 AA 48 2F 05
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/41, len 250
47w0d: RADIUS:  authenticator 43 A5 8D B9 BE 15 4D 74 - 60 46 82 09 98 E3 5E 2B
47w0d: RADIUS:   02 C0 00 0E 01 61 6E 6F 6E 79 6D 6F 75 73         [ anonymous]
47w0d: RADIUS:   8F 4C 22 E3 26 7E B6 15 50 D2 68 41 E9 6C D0 5B         [ L"&~PhAl[]
47w0d: RADIUS: Received from id 1645/41 10.10.201.35:1812, Access-Challenge, len 145
47w0d: RADIUS:  authenticator E7 D6 D3 DA 6D 90 D7 1B - 05 0B 98 9D D4 16 B0 7C
47w0d: RADIUS:   30 34 39 35 35 37 36 2F 32 30 36 38 3B     [ 0495576/2068;]
47w0d: RADIUS:   01 0D 00 1A 2B 21 00 04 00 10 99 F1 1A C8 CF AB D4 DE 28 0D 01 41 E2 43 98 7B            [ +!(AC{]
47w0d: RADIUS:   D9 C1 98 24 AC 84 3E 06 5C E6 6D F0 F8 30 D3 C2             [ $>\m0]
47w0d: RADIUS(00000202): Received from id 1645/41
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/42, len 605
47w0d: RADIUS:  authenticator 8D E8 EA 2D 0F 71 9F 03 - AF D5 0A BD B8 C2 FD 10
47w0d: RADIUS:   02 0D 01 20 2B 01 16 03 01 01 15 01 00 01 11 03 01 6A A9 81 95 A1 7A A4 6D F5 72 C3 04 D6 35 F2 28 50 0A 56 52 3F 50 70 7F 95 81 A2 13 1B 02 AC BE 00 00 1A C0 14 C0 0A 00 39 00 35  [ +jzmr5(PVR?Pp95]
47w0d: RADIUS:   9B DE 3C E4 73 85 5F 80 A5 94 59 DD 21 8C 37 F3            [ <s_Y!7]
47w0d: RADIUS: Received from id 1645/42 10.10.201.35:1812, Access-Challenge, len 273
47w0d: RADIUS:  authenticator E4 C2 D9 FC 92 AA 73 DF - 8F 88 D0 9A 87 6A 98 85
47w0d: RADIUS:   01 0E 00 9A 2B 01 16 03 01 00 54 02 00 00 50 03 01 84 DD 63 8E 4A 2C E5 6F 89 C6 69 42 C3 DE C4 78 CC FE BB 57 F2 E8 E8 C1 6B 76 11 0B 36 38 1B 28  [+TPcJ,oiBxWkv68(]
47w0d: RADIUS:   20 B4 7E B2 59 91 39 BB 8A 2D 14 8B 75 B9 14 50 3D A4 AB 93 3B 11 89 6B 0D 65 84 C2 AF E1 AC F8 5F C0 14 00 00 08 00 0B 00 04 03 00 01 02 14 03 01 00 01 01 16 03 01 00 30 23 29 C7 9E 5B  [ ~Y9-uP=;ke_0#)[]
47w0d: RADIUS:   01 31 03 7E B8 36 7E 0F 91 6B 48 B0 F2 14 A7 D3 58 AB D6 12 F7 4D 5D AB 70 AD 4B B5 13 8C 15 29 E2 FE F1 82 C8 79 A0 E3 31 16 69   [ 1~6~kHXM]pK)y1i]
47w0d: RADIUS:   97 35 65 00 85 D4 FF 44 AE 89 4C EA 9D 55 F4 13             [ 5eDLU]
47w0d: RADIUS: COA  received from id 81 10.10.201.35:47831, CoA Request, len 211
47w0d: RADIUS(00000202): Received from id 1645/42
47w0d: RADIUS(00000000): Send CoA Nack Response to 10.10.201.35:47831 id 81, len 41
47w0d: RADIUS:  authenticator 5D C6 66 BB 82 A2 5E F0 - BE 4A E8 66 D2 10 51 1D
47w0d: RADIUS:  Reply-Message       [18]  15
47w0d: RADIUS:   52 65 71 20 69 6E 69 74 20 66 61 69 6C     [ Req init fail]
47w0d: RADIUS:  Dynamic-Author-Error[101] 6   Resource Unavailable      [506]
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/43, len 1018
47w0d: RADIUS:  authenticator 21 20 B5 53 BF 78 3A 00 - AC 5C 19 50 D2 AA CF B5
47w0d: RADIUS:   02 0E 02 BB 2B 01 14 03 01 00 01 01 16 03 01 00 30 80 BD 29 C0 60 43 57 AB 27 70 59 AD 01 CC B9 35 7D 38 BA 33 49 9E 2C 9F 36  [+0)`CW'pY5}83I,6]
47w0d: RADIUS:   EF E4 E4 E3 98 D0 BE CB 57 BC 6B 9C 6C 82 D4 D9 43 80 E8 86 DA A0 D7 17 03 01 00 20 A8 80 81 67 AF A1 47 F9 A1 7C AD E5 91 7D 71 C9 B3 59 6D 47 15 B2 7D AD 9F 5D 75  [WklC gG|}qYmG}]u]
47w0d: RADIUS:   3A 21 D8 D2 CC 17 03 01 02 50 79 01 03 DF 7F D1 EC 38 90 CE 91 C1 74 B8 04 B4 C2 B8 2F 57 6A 42 C6 B7 FE 31 2A F0 57 BF 0A D0 61 76 B3 FE FA 56  [:!Py8t/WjB1*WavV]
47w0d: RADIUS:   8C 2A B3 D2 76 EF 1F 0B 76 47 DB E6 E1 74 5E 49 11 4E 7E 54 32 2D 3B A5 97 1F E0 82 F1 34 59 D7 23  [*vvGt^IN~T2-;4Y#]
47w0d: RADIUS:   DB F2 6B 73 19 AC D9 16 CE BA 0C FB E5 C2 29 CD E3 E5 75 18 8B 9B 20 07 CC 95 80 3A 35 D2 B2 93 2D 80 19 19 42 8E 86 23 16 4C CB 29 9B 04 9A 5E 04 D1 4B FB D9 AA 6A EE 46  [ks)u :5-B#L)^KjF]
47w0d: RADIUS:   59 2E EB 72 E5 AA BF C7 AA EF DA 7A 7D 6C 79 05 BC 9A           [ Y.rz}ly]
47w0d: RADIUS:   2C D7 AA 17 24 8B 11 57 22 A3 AD 50 C1 EC 86 3E 07 F5 27 53 FC 6F F2 E1 06 6A F2 99 FF 32 F7 9F BE B8 37 BB F8 23 D5 01 D7 8E 1F E2 AE 7E BF 94 95 13 2A 98 9F 51  [,$W"P>'Soj27#~*Q]
47w0d: RADIUS:   5A DB A5 F6 3D 7D 16 1A A4 1C 68 B2 C3 28 C8 64 E7 C7 49 95 4E 2A 4C 40 34 BB 8E 6F DA 63 D2 A0 09 66 9B 4E  [Z=}h(dIN*L@4ocfN]
47w0d: RADIUS:   4D 7E 95 EB CF D9 E9 8A 7B 02 0C E4 3D 18 CE 72 4D 4E 48 F8 B9 5C A9 EB 6E 30 A5 42 38 DC 0E 9F C7 B7 7A 72 15 D2 22  [M~{=rMNH\n0B8zr"]
47w0d: RADIUS:   55 95 24 72 46 60 54 7F 84 B6 B7 49 41 74 A8 41 D8 69 2B 81 D2 0E 93 32 0B 8D CA 04 6F E0 FA D6 2C 51  [U$rF`TIAtAi+2o,Q]
47w0d: RADIUS:   BB F8 49 E5 2C 9A 2B E4 05 49 F1 88 4E 84 84 B4 94 0F 34 BB 83 97 0B D1 D7 EC 16 A7 35 30 45 AD 70 5D 3D 97 70 FA 7A 92 E5 62 C1 EA 4C  [I,+IN450Ep]=pzbL]
47w0d: RADIUS:   77 3E 6A A5 73 7A 24 2F 18 F4 10 E4 D3 CD 30 9F B5 94 73 7C 2F AB 1D 26 CD 17 9A E6 D7 CA 88 DF F2 55 0F E8 87 CF 02 D3 52 92 59 00 B1   [ w>jsz$/0s|/&URY]
47w0d: RADIUS:   A7 EA AD 3B 05 DF 23 B7 31 D0 30 F7 8A F3 C1 2C D7 30 8C EB B9 F2 0F 44 B0 E9 D8 83 14 5C AA 6A 2E 8D A2 75 4F 56 92 62 CA 9E 05 CC 41 FC E5 B8 9F EB 19 6C  [;#10,0D\j.uOVbAl]
47w0d: RADIUS:   25 27 7B C1 25 A3 6A C1 A4 00 0E D1 8B C1 6C 99 58 83 8E 1D 28 7C 7F 1D 78 26 30 BE 30 94 2D 87 0D CB F7 A2 46 25  [?'{?jlX(|x&00-F?]
47w0d: RADIUS:   78 D0 89 A7 14 F9 E3 C7 71 23 B7 7B 72 44 68 36 4E 9A FD FF 46 9E 11 6E 94 55 16 3B 82 00 92 13 A5 14 CB 5E 62 55  [xq#{rDh6NFnU;^bU]
47w0d: RADIUS:   E6 A7 73 F8 D4 5F CD A9 85 71 DE 61 64 08 B9 0B 6F 06 38 76 59 99 19 26 7F 18 AD F7 34 80 A9 74 23 2D 7B C3 DC 5C  [s_qado8vY&4t#-{\]
47w0d: RADIUS:   EC EE 5F ED 98 FD BF B9 46 37 21 16 7E 28 B6 6D 59 1D A5 E4 72 03 B1 EE E8 6F ED        [ _F7!~(mYro]
47w0d: RADIUS:   04 79 BA 41 2E E7 D5 12 BF A0 84 08 AE 34 E6 32             [ yA.42]
47w0d: RADIUS: Received from id 1645/43 10.10.201.35:1812, Access-Challenge, len 162
47w0d: RADIUS:  authenticator E1 5D B2 6A C1 76 A5 18 - D4 4B 07 0A DF 3A 65 7D
47w0d: RADIUS:   01 0F 00 2B 2B 01 17 03 01 00 20 75 A4 F0 FC 98 F8 F7 F1 CC C2 91 CA 57 61 53 41 3F A2 6D 3B D0 95 FC 96 8E 1F E0 79 9D 10 04 6D     [ ++ uWaSA?m;ym]
47w0d: RADIUS:   02 FE 13 B7 CE 38 B1 4A 36 C4 6D 7D C0 5D 33 DB           [ 8J6m}]3]
47w0d: RADIUS(00000202): Received from id 1645/43
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/44, len 395
47w0d: RADIUS:  authenticator 90 49 82 07 01 3E 66 9C - 01 49 AE 0E E2 13 CF 0C
47w0d: RADIUS:   02 0F 00 50 2B 01 17 03 01 00 20 A4 1C 3B 3C CE 5B 9D D8 FB A3 90 C3 3F C2 C3 DA 52 45 FD 0B 2E 70 9B 15 06 EE A4 80 D7 B0 DB AC 17 03 01 00 20 99 F4 15 6D C5 D6 9E 20 FB CB E6 41 66  [P+ ;<[?RE.p m Af]
47w0d: RADIUS:   4A D2 EB C9 85 6A 62 E4 C6 F0 E4 22 B6 36 36 AF 40 FB 4F          [ Jjb"66@O]
47w0d: RADIUS:   3A F4 1D 78 84 25 59 02 27 88 7B 3E 8F 8D 2D A1          [ :x?Y'{>-]
47w0d: RADIUS: Received from id 1645/44 10.10.201.35:1812, Access-Accept, len 684
47w0d: RADIUS:  authenticator 06 75 33 AF 8D 44 D1 F4 - D1 13 99 F9 65 36 5E 95
47w0d: RADIUS:   36 2F 32 30 36 38            [ 6/2068]
47w0d: RADIUS:   03 0F 00 04
47w0d: RADIUS:   05 D3 19 DC EC 50 93 C1 AF 48 E9 98 58 29 42 F5             [ PHX)B]
47w0d: RADIUS:   Cisco AVpair       [1]   184 "url-redirect=https://10.10.201.35:8443/portal/gateway?sessionId=0A0AFB46000000C09EDE6067&portal=a6bb0db0-2230-11e6-99ab-005056bf55e0&action=cpp&token=0566ec38492c58b1572b35516aaf0030"
47w0d: RADIUS(00000202): Received from id 1645/44
47w0d: RADIUS: Received from id 1646/83 10.10.201.35:1813, Accounting-response, len 20
47w0d: RADIUS: COA  received from id 82 10.10.201.35:47831, CoA Request, len 211
47w0d: RADIUS(00000000): Send CoA Ack Response to 10.10.201.35:47831 id 82, len 20
47w0d: RADIUS:  authenticator DC F5 7B 4C CC B8 C6 CA - 81 28 82 01 A8 A8 EA 46
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/45, len 250
47w0d: RADIUS:  authenticator 3D 3D EE FF CC 4B D8 7E - D7 41 AA F1 A1 FB FC F1
47w0d: RADIUS:   02 10 00 0E 01 61 6E 6F 6E 79 6D 6F 75 73         [ anonymous]
47w0d: RADIUS:   07 7E D7 CB F3 97 AE E4 35 99 10 9E 0A 84 22 F8               [ ~5"]
47w0d: RADIUS: Received from id 1645/45 10.10.201.35:1812, Access-Challenge, len 145
47w0d: RADIUS:  authenticator 30 70 15 38 3E 58 7C 76 - FA C0 CF 05 2E FA 4A E8
47w0d: RADIUS:   30 34 39 35 35 37 36 2F 32 30 37 30 3B     [ 0495576/2070;]
47w0d: RADIUS:   01 6B 00 1A 2B 21 00 04 00 10 99 F1 1A C8 CF AB D4 DE 28 0D 01 41 E2 43 98 7B           [ k+!(AC{]
47w0d: RADIUS:   84 FC 16 6E 56 C4 F5 C9 02 83 6E 90 1E 79 9A 0B              [ nVny]
47w0d: RADIUS(00000202): Received from id 1645/45
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/46, len 605
47w0d: RADIUS:  authenticator AE 8D 2D 33 BB 68 E1 41 - D0 A0 73 34 9C 3F 82 FF
47w0d: RADIUS:   02 6B 01 20 2B 01 16 03 01 01 15 01 00 01 11 03 01 FF 2B 5F DC 9A 74 92 75 23 B4 74 C1 B7 0B BF 07 CC 8B 0F C6 52 17 FC F8 36 02 01 8A F7 5E 17 E3 00 00 1A C0 14 C0 0A 00 39 00 35 C0 13 C0 09 00 33 00 2F  [k ++_tu#tR6^953/]
47w0d: RADIUS:   C0 12 C0 08 00 16 00 0A 00 FF 01 00 00 CE 00 23 00 B4 00 02 00 B0 00 03 00 01 00 04 00 10 99 F1 1A C8 CF AB D4 DE 28 0D 01 41 E2 43 98 7B 00 06 00 94 00 03 01 00 F4 24 88 8C 8C 9E B9 7B 3D 1C E7 EC 3A E2 EB 7E 00 00 00 13 58 DA 25 25 00 09 3A 80 3F A0 48  [#(AC{${=:~X??:?H]
47w0d: RADIUS:   D9 87 B3 E6 00 A6 A0 A1 88 3F 37 12 B4 F9 4F B0 60 E2 15 1B E0 27 5C 37 1D 46 5D C0 8A EA 02 3E 5F 19 60 1A ED 96 E4 5F 73 04 33 AD EA 87 8B 51  [?7O`'\7F]>_`_s3Q]
47w0d: RADIUS:   F6 29 06 66 EC B6 FD 4C 40 6F 25 A5 68 B6 BA B9 0A EF BB 93 D2 A0 22 62 6A 51 2E C4 D8 E2 AB AA A1 84 44 58 EE 2B 05 AF 32  [)fL@o?h"bjQ.DX+2]
47w0d: RADIUS:   D0 54 2D A0 73 3E DD D8 F5 2C A8             [ T-s>,]
47w0d: RADIUS:   07 C2 60 39 D0 59 C5 F1 D0 FF 27 C7 A5 89 11 4C             [ `9Y'L]
47w0d: RADIUS: Received from id 1645/46 10.10.201.35:1812, Access-Challenge, len 273
47w0d: RADIUS:  authenticator D9 F6 69 74 8F F4 AC E2 - 22 85 A9 94 2D 96 B3 DD
47w0d: RADIUS:   01 6C 00 9A 2B 01 16 03 01 00 54 02 00 00 50 03 01 B5 8D 15 08 F6 36 9C 7B 8F 74 D0 ED 28 12 4D 00 43 AD 5B 8D F1 B7 87 77 0E A5 EF 25 97 7D 00 1B 20 73  [l+TP6{t(MC[w?} s]
47w0d: RADIUS:   79 C4 9E C2 37 14 56 6B 6F 1C 4A 27 D7 9F 6A D3 F7 8F 47 F6 6A C9 3B 36 9A 2D 61 84 11 A6 11 C0 14 00 00 08 00 0B 00 04 03 00 01 02 14 03 01 00 01 01 16 03 01 00 30 E0 11 01 4C  [y7VkoJ'jGj;6-a0L]
47w0d: RADIUS:   BA 14 56 1F EB B4 4F D5 C8 18 32 28 72 71 C3 AD 10 66 B8 69 75 FD F0 AA 6A F2 41 44 32 2E 71 4C  [VO2(rqfiujAD2.qL]
47w0d: RADIUS:   B4 AB CC 86 DC C0 12 A5 87 2D 32 7F                [ -2]
47w0d: RADIUS:   C6 8E 18 C1 28 A2 54 DF 23 05 AA 4D 54 FA 43 85            [ (T#MTC]
47w0d: RADIUS(00000202): Received from id 1645/46
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/47, len 1018
47w0d: RADIUS:  authenticator 24 66 80 CF 2A AA 04 CD - 1E E7 A3 14 F1 DE 09 39
47w0d: RADIUS:   02 6C 02 BB 2B 01 14 03 01 00 01 01 16 03 01 00 30 9E 63 1D D8 6D C2 62 90 CA F8 8E E1 77 57 DC 4D AF 5A 15 3C B8 8C A5 D7 16 88 1F 10 A0 DE 55 51 0F 2D 8E 56 ED E3 98 FD EF B4 B7 1A 68  [l+0cmbwWMZ<UQ-Vh]
47w0d: RADIUS:   3F 13 D2 17 03 01 00 20 3E DC BF DC 41 1F 5E 63 80 50 30 24 43 7F F6 0B 05 E8 D4 7D 1C E0 E9 95 E8 DD BE B9 87 D8 64 85 17 03 01 02 50 A7 A3 8B 8D BB 90 C3 31 04 92 11 61 7D  [? >A^cP0$C}dP1a}]
47w0d: RADIUS:   AD 39 36 2C 04 6F DA 45 46 26 5C 7C 09 A3 14 1C 4A D1 7B 32 10 68 53 6E EC 3F  [96,oEF&\|J{2hSn?]
47w0d: RADIUS:   5E F0 D0 6E 59 D7 14 40 08 C6 AF 28 1B 63 A9 9B 2E D7 88 58 6F D3 46 A7 AF 92 A9 20 02 49 D1 1E DA 99 FA 75 BB C1 86 CA 96 54 EB 93 2E 55  [^nY@(c.XoF IuT.U]
47w0d: RADIUS:   2D B6 2E CC BB 79 F6 CF BE AF CE B5 3B 10 22 30 DF E6 2F FA 8D FD 9E F1 F0 4A B1 2E C4 94 A3 6D 69 82 BC 59 A9 7D 57 5A 55  [-.y;"0/J.miY}WZU]
47w0d: RADIUS:   B5 AE 2A 60 41 FA 35 60 BF 95 C9 10 0A CF 30 68 60 78 9D E7         [ *`A5`0h`x]
47w0d: RADIUS:   D6 7E 3D 12 0B 58 B0 CB 67 5D C7 7D 5E 41 F2 28 EB 9F 75 75 26 6E 66 A2 3B BC 25  [~=Xg]}^A(uu&nf;?]
47w0d: RADIUS:   0D E0 9C 3E EE 73 A5 AA 70 D5 AF 11 6A A6 D9 AF B2 63 32 9E ED 8A 31 A3 5D 25 15 C3 76 4F A2 2A 84 BE 32 F5 FE 04 E5 46 52 FD A2 88 EA B5 01 A4 55  [>spjc21]?vO*2FRU]
47w0d: RADIUS:   A0 52 47 96 60 44 FF 14 78 3A 2F 99 18 1E 90 4A F4 C6 64 AA F4 D0 A7 56 B1 1E E2 90 6F DD CC AF 2F 8C 82 AD C1 5E 3F 82 BB 3A BB D1 5D  [RG`Dx:/JdVo/^?:]]
47w0d: RADIUS:   87 B8 5E A7 D1 B3 BC 33 FD 82 FB 6F 0B 2C 01 A5 2F 0D 20 A3 8F 20 BC 50 C5 AC 4B CF CB A2 35 F5 EE 0D A4 93 D5 D9 43 11 1F FE 1D F8 D5 ED 70 B2 BA E8 D0 81 D2 05 B3 BB 53 77 2D 16 00 26  [^3o,/  PK5CpSw-&]
47w0d: RADIUS:   97 60 77 5B 34 C8 2F 88 60 9C 24 B0 E2 DD 31 7D 20 B5 3B FE 00 14 FA 77 9B 09 59 F8 39 E5 6B EA 71  [`w[4/`$1} ;wY9kq]
47w0d: RADIUS:   34 1A 46 4D 79 E4 BC 45 B7 E3 64 21 46 B0 DF 10 EA CF E6 79 FF 8C 08 F4 62 AA 1C A2 28 9A 6F A2 21 0A 62 7B C5   [ 4FMyEd!Fyb(o!b{]
47w0d: RADIUS:   80 0A FD ED D9 21 ED 13 C4 9B 4A 96 95 42 40 BE 7D A8 41 9F 59 85 2B C0 7C E1 F8 0B 9D 8D 15 37 B5 E6 60 08 26 CA 06 8F D4 12 C7 33 7E 49 7A  [!JB@}AY+|7`&3~Iz]
47w0d: RADIUS:   D2 F0 E6 3F E6 0F 43 E4 2C 3B 5B DD 96 C7 D2 78 29 48 9E 44 E3 2B 8E B0 ED 37 D0 19 C0 E2 EB B9 0C 6D D4 14 8A 5E EE 0E 0A 5E 2B 2F  [?C,;[x)HD+7m^^+/]
47w0d: RADIUS:   7C 6D EB 57 C2 AA 6D 3A F0 18 5C 79 2C 35 53 18 F7 37 C4 99 98 1E D9 A2 58 BF 1A 34 8D E6 64 62 2D  [|mWm:\y,5S7X4db-]
47w0d: RADIUS:   4B 90 A9 7A FD 34 FF 30 59 60 B3 07 96 7D 0C D3 93 F8 FE 98 D7 6B 17 3B 87 18 8F B7 BD F3 9B 78 49 05 01 C6 A2 84 81 00 BB 19 E5 21 2F 80 9E B2 6C B5 B0 68 83 5B  [Kz40Y`}k;xI!/lh[]
47w0d: RADIUS:   D3 14 EE 1E 52 A3 F6 A6 CA 9D E2 D3 6C CF F4                [ Rl]
47w0d: RADIUS:   EA D1 57 78 20 55 6F 0F A7 A3 55 A0 3D 9D 1C CE           [ Wx UoU=]
47w0d: RADIUS: Received from id 1645/47 10.10.201.35:1812, Access-Challenge, len 162
47w0d: RADIUS:  authenticator 5F 0A 9F 1C EE CB 38 FA - 62 69 64 B8 96 F6 2A 40
47w0d: RADIUS:   01 6D 00 2B 2B 01 17 03 01 00 20 B6 55 1D 62 D9 71 8E F1 F9 AF B2 10 F4 7E 46 8C C4 37 50 C8 93 67 0D 22 34 D8 A8 53 22  [m++ Ubq~F7Pg"4S"]
47w0d: RADIUS:   1B FF 52                 [ R]
47w0d: RADIUS:   C1 36 5B 9B 64 F0 18 B3 86 99 92 82 48 02 A1 3C             [ 6[dH<]
47w0d: RADIUS(00000202): Received from id 1645/47
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/48, len 395
47w0d: RADIUS:  authenticator F3 D2 FD 94 B0 52 3C 6A - 36 93 33 36 56 2D C0 9C
47w0d: RADIUS:   02 6D 00 50 2B 01 17 03 01 00 20 EF 47 8F E5 C1 84 C7 51 43 8F 42 79 3F 90 B4 EF 77 79 5E A6 B6 50 EB 0B 08 B1 27 F9 7C  [mP+ GQCBy?wy^P'|]
47w0d: RADIUS:   66 81 B2 17 03 01 00 20 A7 E8 E6 DC F6 A9 3B 16 1F 9A 9A EA BE 3C 38 8C 1D 43 84 6A 45 0E 26 37 BE 40 4F D1 49 57 09 B0    [ f ;<8CjE&7@OIW]
47w0d: RADIUS:   27 03 F6 76 BC A7 1C 79 ED 30 6B AA E7 BF F5 C7             [ 'vy0k]
47w0d: RADIUS: Received from id 1645/48 10.10.201.35:1812, Access-Accept, len 652
47w0d: RADIUS:  authenticator 2D 2B 88 55 A2 11 4B CA - BA A5 1A 99 AE 1E 88 D2
47w0d: RADIUS:   36 2F 32 30 37 30            [ 6/2070]
47w0d: RADIUS:   03 6D 00 04                 [ m]
47w0d: RADIUS:   9A 60 72 2B A6 5A B7 25 8C 0B 9E 22 38 78 8B 36         [ `r+Z?"8x6]
47w0d: RADIUS:   Cisco AVpair       [1]   184 "url-redirect=https://10.10.201.35:8443/portal/gateway?sessionId=0A0AFB46000000C09EDE6067&portal=a6bb0db0-2230-11e6-99ab-005056bf55e0&action=cpp&token=120779122045609ab48d3c302401a987"
47w0d: RADIUS(00000202): Received from id 1645/48
47w0d: RADIUS: Received from id 1646/84 10.10.201.35:1813, Accounting-response, len 20
47w0d: RADIUS: COA  received from id 73 10.10.201.35:31697, CoA Request, len 224
47w0d: RADIUS(00000000): Send CoA Ack Response to 10.10.201.35:31697 id 73, len 20
47w0d: RADIUS:  authenticator 97 BB 37 15 10 23 F0 F7 - E3 EE 8A D8 5F EE 67 4A
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/49, len 250
47w0d: RADIUS:  authenticator 5C F5 44 92 FF 27 63 54 - FA 20 CD 53 48 5D F8 C3
47w0d: RADIUS:   02 6E 00 0E 01 61 6E 6F 6E 79 6D 6F 75 73        [ nanonymous]
47w0d: RADIUS:   C5 15 E2 95 CD 6E 32 23 A1 BF FD 05 36 14 90 54             [ n2#6T]
47w0d: RADIUS: Received from id 1645/49 10.10.201.35:1812, Access-Challenge, len 145
47w0d: RADIUS:  authenticator 35 23 A9 7A C4 8A BD 4A - 28 93 66 85 B2 C2 59 78
47w0d: RADIUS:   30 34 39 35 35 37 36 2F 32 30 37 35 3B     [ 0495576/2075;]
47w0d: RADIUS:   01 A2 00 1A 2B 21 00 04 00 10 99 F1 1A C8 CF AB D4 DE 28 0D 01 41 E2 43 98 7B            [ +!(AC{]
47w0d: RADIUS:   5D 0B 91 C9 4D F7 FB FF 32 9F DC B8 6D C5 0E 1B              [ ]M2m]
47w0d: RADIUS(00000202): Received from id 1645/49
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/50, len 605
47w0d: RADIUS:  authenticator 99 0D 20 E9 E0 3C 2E 0D - A0 BB B4 63 C8 4C 37 56
47w0d: RADIUS:   02 A2 01 20 2B 01 16 03 01 01 15 01 00 01 11 03 01 5B 5D 0D 05 42 C8 DA 2A 33 A5 D0 81 C6 38 9B D4 C7 D1 DE E4 E2 40 27 66 ED 44 35 26 EB 1C 9E 5C 00 00 1A C0 14 C0 0A 00 39  [ +[]B*38@'fD5&\9]
47w0d: RADIUS:   00 35 C0 13 C0 09 00 33 00 2F C0 12 C0 08 00 16 00 0A 00 FF 01 00 00 CE 00 23 00 B4 00 02 00 B0 00 03 00 01 00 04 00 10 99 F1 1A C8 CF AB D4 DE 28 0D 01 41 E2 43 98 7B 00 06 00 94 00 03 01 00 F4 24 88 8C 8C 9E B9 7B 3D 1C E7 EC 3A E2 EB 7E 00 00 00 13 58 DA 25 25  [53/#(AC{${=:~X??]
47w0d: RADIUS:   00 09 3A 80 3F A0 48 D9 87 B3 E6 00 A6 A0 A1 88 3F 37 12 B4 F9 4F B0 60 E2 15 1B E0 27 5C 37 1D 46 5D C0 8A EA 02 3E 5F 19 60 1A ED 96 E4 5F  [:?H?7O`'\7F]>_`_]
47w0d: RADIUS:   73 04 33 AD EA 87 8B 51 F6 29 06 66 EC B6 FD 4C 40 6F 25 A5 68 B6 BA B9 0A EF BB 93 D2 A0 22 62 6A 51 2E C4 D8 E2 AB AA A1 84 44  [s3Q)fL@o?h"bjQ.D]
47w0d: RADIUS:   58 EE 2B 05 AF 32 D0 54 2D A0 73 3E DD D8 F5 2C A8          [ X+2T-s>,]
47w0d: RADIUS:   10 EA 85 F8 64 94 4C 7E BD A8 F6 A5 0C 0D 55 83              [ dL~U]
47w0d: RADIUS: Received from id 1645/50 10.10.201.35:1812, Access-Challenge, len 273
47w0d: RADIUS:  authenticator E7 55 1C 08 40 61 3C 94 - 4D 4D 1E 53 37 06 11 CC
47w0d: RADIUS:   01 A3 00 9A 2B 01 16 03 01 00 54 02 00 00 50 03 01 D1 0B 2B FC EF A4 7D BA 65 7F 88 89 CC 79 58 1D 1B 99 A4 DC BE 2E B2 1C B5 0B 28 6F F7 32 B9 E5 20 2F 8B E5 8C D8 45 C0 83 CB 6F  [+TP+}eyX.(o2 /Eo]
47w0d: RADIUS:   36 7E 79 8E 70 44 C9 50 11 3F 72 17 B4 87 B3 B2 92 6A C6 75 2D 93 C0 14 00 00 08 00 0B 00 04 03 00 01 02 14 03 01 00 01 01 16 03 01 00 30 5C 17 CD F5 E3 17 43 B1 5E 74  [6~ypDP?rju-0\C^t]
47w0d: RADIUS:   CD 77 55 C0 12 A9 80 BD EA 6F 70 14 58 BD 36 F4 7D 63 C5 6A CE 53 C0 D7 A5 47 17 10 31 1A D5 77 C5 37 DE 15 11 39   [ wUopX6}cjSG1w79]
47w0d: RADIUS:   74 58 1B E6 27 8B 82 C3 06 D8 1B D9 C5 F3 1E C5               [ tX']
47w0d: RADIUS(00000202): Received from id 1645/50
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/51, len 1018
47w0d: RADIUS:  authenticator 7A 52 BB A7 DB 4C 3C 33 - 30 E5 08 64 0A 82 76 71
47w0d: RADIUS:   02 A3 02 BB 2B 01 14 03 01 00 01 01 16 03 01 00 30 6F 85 F9 6F 73 39 04 BD C2 5E F0 AF 12 4D 7A 55 3A C1 3D 55 5D DD 83 A4 AE 4E 55  [+0oos9^MzU:=U]NU]
47w0d: RADIUS:   F3 7A 14 0F C7 29 50 99 1C 86 73 6C 30 AC CD EB E3 DB 19 ED 39 17 03 01 00 20 32 6A 42 B4 09 BD E8 EA 26 B9 11 50 D2 CA C4 00 BE D4 B8 E8 F9 7A 37 31  [z)Psl09 2jB&Pz71]
47w0d: RADIUS:   6B 81 BF 6B 46 2B B6 D5 17 03 01 02 50 1C FE B1 CC 4A 41 98 BA B2 CC 51 B3 54 DA 40 2F 20 A5 D8 6E 23 FE 49 F6 A0 14 8B E2 F0 DF 65  [kkF+PJAQT@/ n#Ie]
47w0d: RADIUS:   91 3C 81 09 D2 B6 8B 38 F6 98 D4 C2 01 B4 9D 5F AE 15 B6 5E 86 D6 B3 2F F4 B5 85 0D F0 A8 69 BB 6C 73 A8 54 EA 66 33 56 8E EA 05 4D 60 93 89 3B 39  [<8_^/ilsTf3VM`;9]
47w0d: RADIUS:   AD DC F6 F3 E4 4E 63 47 69 77 89 A6 02 50 47 1B 8E 4C 34 78 EF 71 69 83 BE 75 FB 10 9A E2 91 1F E4 03 89 B9 BC 93 23 FA 83 E9 50 F2 8E 1B 02 A7 2A  [NcGiwPGL4xqiu#P*]
47w0d: RADIUS:   84 57 33 7F F9 46 2D C3 A3 73 D7 DC 7C 56 F7 29 02          [ W3F-s|V)]
47w0d: RADIUS:   56 4D 4B BC C6 86 3E 37 17 E3 31 5D 64 9A 61 0D DE 57 12 A7 FA 5C 5D D8 56 1D C4 F6 6A FE 7F AD FB CB AC 0C 8C 4D FE 71  [VMK>71]daW\]VjMq]
47w0d: RADIUS:   57 B1 E4 51 D3 31 29 89 BD 4A A5 94 A6 28 1A 93 3D 69 3D 82 EE 52 24 56 B5 62 8B 47 94 5B 14 6E  [WQ1)J(=i=R$VbG[n]
47w0d: RADIUS:   6A C4 A7 AB 89 A5 7B 47 5C 15 8B E2 C8 6B DF 7E A6 DB E2 FA 6A D9 ED 49 BC C2 21 43 FC 3C E1 D1 74 5A 7D 4E 9E FB 96 D6 E7 B6 E1 E9 25  [j{G\k~jI!C<tZ}N?]
47w0d: RADIUS:   A6 B1 E2 88 38 DF C4 57 E3 00 8A 58 76 85 3F AD A1 6B 99 EC 41 20 AC 1A E0 3E F4 FE 82 75 5B 44 15 9B E1 A8 DE 2E DD DD 17 5A D7 59 47  [8WXv?kA >u[D.ZYG]
47w0d: RADIUS:   01 58 6E 8E 3A E4 B9 53 13 A6 F7 ED 81 21 42 0B F0 41 D2 B3 14 76 8B 3B F0 88 65 44 95 D7 43 A3 D2 26 DE 90 36 71 5D  [Xn:S!BAv;eDC&6q]]
47w0d: RADIUS:   F3 15 31 D7 F9 D5 E3 FB 75 12 8D 14 71 C6 5B 92 BA 9F 5C BD 97 59 61 3E 80 F3 AA 95 7B FC B2 11 F6 10 40 1B 70 92 06 06 A1 9B 84 65 F5 EA 84 CC 2C E5 80 C3     [ 1uq[\Ya>{@pe,]
47w0d: RADIUS:   CE C8 8B 62 40 E3 47 66 A8 47 73 9A 92 35 4D EB 11 95 4D 21 7E FA E4 F5 22 8D C6 38 73 DA E6 CD F3 37 FA 42  [b@GfGs5MM!~"8s7B]
47w0d: RADIUS:   F6 1F F1 A4 F3 DE 5F B9 E6 A6 29 94 71 C4 1A 31 D7 55 82 3F 76 39 8A C0 90 70 56 B7 65 10 83 5E EB 70 FC 1E A5 BF 5A 87 34 14 2D  [_)q1U?v9pVe^pZ4-]
47w0d: RADIUS:   62 DD 37 ED 49 3D 26 6B 31 D4 33 A6 8D 4C 58 CC 99 02 20 25 F4 7E CB 26 00 FA 50 57  [b7I=&k13LX ?~&PW]
47w0d: RADIUS:   47 B8 22 3B 24 52 3B 94 40 95 0B F2 52 C5 B4 1E F3 DE 22 A9 B6 C6 3B F6 73 4F 6C C6 08 8D 1E 29 34 FD EE 5B  [G";$R;@R";sOl)4[]
47w0d: RADIUS:   13 F2 E7 7E 18 40 24 65 12 D3 CE DE 78 ED DB 2C DD A6 DF 49 89 93 7E EC 30 11 44 AD 5B 19 80 25 76 20 C0 99 4B DA 31  [~@$ex,I~0D[?v K1]
47w0d: RADIUS:   D9 18 DC 5D A0 03 3E C5 FD D3 DD                [ ]>]
47w0d: RADIUS:   F1 0D 6A D8 ED 6F 0E CD 5C FC 9E F0 51 43 1F 71            [ jo\QCq]
47w0d: RADIUS: Received from id 1645/51 10.10.201.35:1812, Access-Challenge, len 162
47w0d: RADIUS:  authenticator 8C 36 63 19 EA F8 95 0B - 73 B5 BD 0E E3 C3 85 FF
47w0d: RADIUS:   01 A4 00 2B 2B 01 17 03 01 00 20 E1 74 62 36 43 BB 41 A4 A1 D5 C4 52 A5 61 A6 AF 59 C4 16 B2 36 60 AA 3C 5E 96 6E  [++ tb6CARaY6`<^n]
47w0d: RADIUS:   8E 33 08 A2 29                [ 3)]
47w0d: RADIUS:   E4 85 BA 18 5C 54 5C 4D E0 D8 D7 EF A4 A8 19 AC              [ \T\M]
47w0d: RADIUS(00000202): Received from id 1645/51
47w0d: RADIUS(00000202): Send Access-Request to 10.10.201.35:1812 id 1645/52, len 395
47w0d: RADIUS:  authenticator 06 0A 40 7B 8C 90 2D A3 - 1F 61 F3 37 53 A9 AE 04
47w0d: RADIUS:   02 A4 00 50 2B 01 17 03 01 00 20 9E 12 93 50 3B F8 7C DE E9 47 DF 7D 9D BF 6F D6 23 ED E8 42 9A F1 85 B9 9F ED 60 CD 76 AD 38 62 17 03 01 00 20  [P+ P;|G}o#B`v8b ]
47w0d: RADIUS:   E4 C4 5A 19 D5 4A 9D C9 B4 98 71 CC 50 08 3A 9C 74 34 90 0C 97 CC 57 38 6C 2E C2 CF F5 13 88 BD       [ ZJqP:t4W8l.]
47w0d: RADIUS:   06 44 64 96 F6 73 FA DE 14 87 14 E7 83 DF EE AD               [ Dds]
47w0d: RADIUS: Received from id 1645/52 10.10.201.35:1812, Access-Accept, len 652
47w0d: RADIUS:  authenticator B7 4E 28 92 60 A3 02 D2 - 5B 87 FB B2 C1 47 06 D8
47w0d: RADIUS:   36 2F 32 30 37 35            [ 6/2075]
47w0d: RADIUS:   03 A4 00 04
47w0d: RADIUS:   4F AE 86 49 41 EE F3 80 67 0A F5 07 C6 01 16 26             [ OIAg&]
47w0d: RADIUS:   Cisco AVpair       [1]   184 "url-redirect=https://10.10.201.35:8443/portal/gateway?sessionId=0A0AFB46000000C09EDE6067&portal=a6bb0db0-2230-11e6-99ab-005056bf55e0&action=cpp&token=e35d496f595c59b51a24232c909dc1bb"
47w0d: RADIUS(00000202): Received from id 1645/52
47w0d: RADIUS: COA  received from id 83 10.10.201.35:47831, CoA Request, len 224
47w0d: RADIUS(00000000): Send CoA Ack Response to 10.10.201.35:47831 id 83, len 20
47w0d: RADIUS:  authenticator 2F 1C 07 B1 6F BD 94 C4 - D3 71 8A 80 34 CA 50 92
47w0d: RADIUS: COA  received from id 74 10.10.201.35:31697, CoA Request, len 224
47w0d: RADIUS(00000000): Send CoA Nack Response to 10.10.201.35:31697 id 74, len 41
47w0d: RADIUS:  authenticator 2C 06 CA FC CB 1D 75 80 - 76 06 0E 00 C8 31 9F 07
47w0d: RADIUS: Received from id 1646/85 10.10.201.35:1813, Accounting-response, len 20
QYS-GFC-SW#u all
All possible debugging has been turned off
QYS-GFC-SW#term mo n            no mon
QYS-GFC-SW#
QYS-GFC-SW#a   sow authe                           sow             ho      show autn   h sess int g1/0/5 de
QYS-GFC-SW#show auth sess int g1/0/5 de
            Interface:  GigabitEthernet1/0/5
          MAC Address:  ecf4.bb7d.cb15
           IP Address:  10.10.10.70
            User-Name:  ise1
               Status:  Running
               Domain:  DATA
      Security Policy:  Should Secure
      Security Status:  Unsecure
       Oper host mode:  multi-domain
     Oper control dir:  both
        Authorized By:  Authentication Server
           Vlan Group:  N/A
     URL Redirect ACL:  redirection
         URL Redirect:  https://10.10.201.35:8443/portal/gateway?sessionId=0A0AFB46000000C09EDE6067&portal=a6bb0db0-2230-11e6-99ab-005056bf55e0&action=cpp&token=e35d496f595c59b51a24232c909dc1bb
              ACS ACL:  xACSACLx-IP-Qiyas_Swithches_Employee_Posture_Unknown-58c660dd
      Session timeout:  N/A
         Idle timeout:  N/A
    Common Session ID:  0A0AFB46000000C09EDE6067
      Acct Session ID:  0x000002F3
               Handle:  0xBA0000C0
Runnable methods list:
--More--
       Method   State
       dot1x    Running
       mab      Not run
QYS-GFC-SW#
QYS-GFC-SW#QYS-GFC-SW#exit
thanks.
the radius requests are sending from switch  to ISE.
from log we can see that you are doing user authentication ( with username 'ise1') and it passed the authentication and authorization phases and it hits the 'Employee_Posture_Unknown' rule under authorization policy.
it seems the behavior is correct.the posture status  for this endpoint is unknown and it hits  this rule.
which rule you want to see this authentication to hit in authorization policy?
about logs, can you please check under 'Operations> Reports >Endpoints and Users > RADIUS Authentications'
if you see any logs?
Beginner
In the live logs, i am not seeing any machine or user authentication session.
Even after restarting the PC and before entering the credential, we are still seeing the default policy, where in fact i should be seeing the computer or user authentication policy.
this is the flow that i am seeing while connecting the PC to network... so from default policy then posture unknown, where in fact the machine and user policy are in between. Also while the PC is taking the unknown policy, the posture module in the client PC is showing "bypassing any connect scan, your network is configured to use NAC agent".
thanks.
please below link:
Manny,
Try disabling your Employee_Posture_Unknown rule.
If there is no posture agent, posture will always be Unknown and therefore you will always have a match this condition and never drop through to your other Machine/User authentications.
