Using ISE instead of FreeRadius with Google Authenticator
N3t W0rK3r
Level 3
Level 3
Does anyone know if this is at all possible?
We are thinking about using GA as MFA for our WEBVPN implementation on our ASA 5525X's.  ISE is v2.1
Thanks.
John
Surendra
I’m not sure what GA is, but if you are trying to do something with ISE that a Free RADIUS server can do, the most likely the answer is yes.
Thanks for you reply.  GA is Google Authenticator.
jason.emery
Did you ever find any solution to this? I'm trying to figure out a similar configuration. Seems strange to have to run an open source radius server to use google authenticator. I could do that and bypass ISE altogether.
