Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
148
Highlighted
Beginner
Validate dns - ISE
Hi, I going to install my first ISE... I watch the video Cisco ISE with WLC Setup Video "Lets install ISE" but i have a ques about configure DNS.
In the video comment 3 objects ISE 20, mydevices and sponsor... is necesary add all? i know about ISE20 is the host name but mydevices and sponsor what is it? for what configure?
Everyone's tags (3)
2 REPLIES 2
Contributor
Re: Validate dns - ISE
The my devices portal is for the BYOD use case. You need that DNS entry if you intend on using BYOD and you want to allow users to manage their own devices (i.e. report them as lost or remove them). The sponsor portal is for the guest use case. You will want DNS for the sponsor portal if you intend on using the sponsored guest flow. Neither of these are required to implement ISE.
George
Keep in mind these are easy URLS (FQDNs) so the users have something easy to remember
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/user_guide/ise_user_guide/ise_webportals.html#29636
Instead of something like this
https://yourise.domain.com:8443/sponsorportal/PortalSetup.action?portal=4c3ca030-e371-11e6-92ce-005056873bd0
They can use sponsor.domain.com
Same for my devices
