ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
165
Highlighted
Participant
VPN and Cellular Users' Authentication using ISE
Hi Champs!
Can we use ISE to authenticate VPN users? If yes, is it possible to do this on Virtual ISE machine?
Could someone please share any config example?
Thanks.
1 ACCEPTED SOLUTION
Re: VPN and Cellular Users' Authentication using ISE
Yes Cisco ISE integrates with the vpn use case
You can use ISE in a virtual machine or physical appliance model
Check out this found in google search
https://supportforums.cisco.com/t5/vpn/asa-5525x-anyconnect-configuration-with-ise-2-1/td-p/2997585
1 REPLY 1
