11-01-2017 03:14 PM
Hi Champs!
Can we use ISE to authenticate VPN users? If yes, is it possible to do this on Virtual ISE machine?
Could someone please share any config example?
Thanks.
Solved! Go to Solution.
11-01-2017 04:47 PM
Yes Cisco ISE integrates with the vpn use case
You can use ISE in a virtual machine or physical appliance model
Check out this found in google search
https://supportforums.cisco.com/t5/vpn/asa-5525x-anyconnect-configuration-with-ise-2-1/td-p/2997585
11-01-2017 04:47 PM
