08-06-2019 10:07 AM - edited 02-21-2020 11:08 AM
Hello everyone,
A client who bought the ISE Apex license want to use the CTA adapter for automatic mitigation actions, he is also using AMP for endpoint, so here is the question:
Does it requires additional CTA license for the CTA or the CTA is included just like the case in Stealthwatch?
Thanks.
Solved! Go to Solution.
08-07-2019 08:17 AM
CTA can be integrated into ISE to take advantage of the TC-NAC system. An ISE Apex license is required to enable the TC-NAC subsystem in ISE.
If your customer already has AMP for Endpoints, they should already have access to CTA. WSA and Stealthwatch also offer this access.
Check here for more information:
08-07-2019 08:17 AM
08-07-2019 08:23 AM
Thanks for the correction, forgot about AMP for endpoint to CTA. Will retract my response.
08-12-2019 05:44 AM
