12-18-2018 02:42 AM
Hi everyone,
I'm running ISE 2.4 Patch 5. I've replicated the issue for Firefox and Chrome. Steps to replicate issue:
1) Go to network devices menu
2) Access a network device
3) Show the password, whether T+ or RADIUS
4) Try to copy the password
5) Once the password disappears, you need to exit the device in order for it to reappear.
The reason you'd want to copy the password is to update device configuration after updating passwords or replacing hardware. So this could be annoying if you have to juggle different passwords for different devices.
I'd like to hear if others have been able to replicate this issue. I haven't seen anything like this in the Bug Tracker.
Thanks for your time, hope to hear from you whether you're able to replicate the issue or not.
Solved! Go to Solution.
12-19-2018 07:34 AM
12-18-2018 05:48 AM
This is normal and been that way for quite a while now. I think this is by design. If you want to get the password you simply export the network device data to a CSV file. If you want to make mass changes you can update the CSV and import. If you are creating a new device, you simply duplicate a device of similar type that already has the password set.
12-18-2018 08:48 AM
12-18-2018 10:11 AM
By design to show the password and then play cat and mouse?
If they didn't want it to be available, there wouldn't be a Show button. It's purely a cosmetic error.
Certainly if you can access the network device you should be able to access the password without having to export a file and then look for the password there.
I see this working just fine in ACS.
12-18-2018 11:32 AM
12-18-2018 05:47 PM
I've not seen such issue in our setups, but some on auto-fill remembered password.
12-18-2018 05:56 PM
12-18-2018 06:48 PM - edited 12-18-2018 06:51 PM
12-18-2018 08:48 PM
Select the password using mouse and right click it , you will get option to copy it.
12-18-2018 07:03 PM
Thanks, paul and Damien Miller. It was not happening to me as I usually use right-click (or second-click) and select from the drop-down to copy.
I found this known bug -- CSCvm07718
12-18-2018 09:13 PM
The bug report would have you believe it's only for Safari/Chrome on a Macbook. I've seen it happen on firefox/chrome on windows 7 and windows 10.
It's also said to be fixed...
12-19-2018 07:34 AM
