08-30-2017 08:01 PM
Hi Forum,
I'm trying to help a customer with locking the wired ports to only company asset macbooks. For wireless JAMF is taking care of that for me by checking mdm>>deviceRegisteredStatus=registered but for wired, JAMF does not have the mac address of the dongle (that changes every time you get new dongle).
Authentication with a cert is not an option here. What's another way to identify corp assets on the wired for Macs??
Solved! Go to Solution.
08-31-2017 10:26 AM
See Trusted Device + Trusted User section of the following Cisco Live session (BRKSEC-3697 - 2017 Melbourne).
Advanced ISE Services, Tips and Tricks (2017 Melbourne)
The reference version of presentation provided additional details.
Access to CiscoLive.com requires one-time registration (no charge).
/Craig
08-31-2017 10:26 AM
/Craig
08-31-2017 08:52 PM
If you are using JAMF then join the Macs to AD and then have JAMF configure the MACs to present AD computer credentials just like you do on a Windows device. No need to even to JAMF MDM integration.
