01-05-2018 11:40 AM
I have some questions from an Active Directory team about exactly what's happening "behind the scenes" when we enable Easy-Connect on an AD controller. Previously there was a script that was run, but now it's all done from the ISE GUI and it's made them very nervous about exactly what is being sent / changed. Can someone provide an explanation of exactly what we're doing to the AD controller when it's added in ISE as an Easy-Connect server?
Solved! Go to Solution.
01-05-2018 02:35 PM
The requirements for Passive ID setup have not changed. We just made it simpler than having to run through steps manually:
The alternative is to run agent on DC or member server and you bypass the settings needed for remote access via DCOM, but core principles apply.
Craig
01-05-2018 02:35 PM
Craig
01-08-2018 05:16 AM
IRT running the agent, it can be run on any member server? I assume then it’s more of an interval based polling rather than real-time / near-time?
Brad Landrum
Systems Engineer | Cisco Systems
SNR: 1.770.236.7927
blandrum@cisco.com
https://acecloud.webex.com/meet/blandrum
01-06-2018 10:55 AM
Adding to what Craig said, we may still either manually configure for what required or run the script ourselves, instead of using the automation by "Configure WMI".
Running a PIC agent is a good option other than that providing PassiveID only but not yet supported for Easy Connect.
