Industrial Networking
Hi, I collect vintage Cisco networking equipment. I have a Cisco PIX 515E.I can't seem to reach the outside internet with it. Here is my config: RDXLFW1# sh ru: Saved:PIX Version 7.2(2)!hostname RDXLFW1enable password 8Ry2YjIyt7RRXU24 encryptednames!...
RadxD461 by Level 1
  • 182 Views
  • 2 replies
Hello! I'm currently working on lab 6.3.2.3 Packet Tracer - Prototype & Test the Solution. The basic logic is to monitor the current status of garage doors. I wanted to add to Home Wireless Router, expect laptop and pc connected to it, one more pc by...
Gugolsan by Level 1
  • 118 Views
  • 0 replies
IE4000 (or Stratix 5400) user question:  Has anyone successfully made VTP version 3 (or v2) work over a PRP interface?   Debug sw-vlan * seems to show the VTP library transmitting VTP on the PR1 meta-interface instead of the underlying physical inter...
I nee to convert the following code from ios to ios xe:!ptp mode boundarymls qos map policed-dscp 24 27 31 43 46 47 55 59 to 0mls qos map dscp-cos 9 11 12 13 14 15 to 0mls qos map dscp-cos 25 26 28 29 30 to 2mls qos map dscp-cos 40 41 42 44 45 49 50 ...
ndongo by Level 1
  • 289 Views
  • 2 replies
I have an IR1101 with Verizon SIM. I have less experience with Cisco cellular, and all experience using Digi, Cradlepoint, and Sierra. With the Digis we use a heartbeat process that pings 1 of 2 IPs, and when both fail it will restart the interface, ...
Hi all. We have had about 37 Cisco IXM-LPWA-800-16-K9 operational for some 2 years now. They have been installed at different locations and powered by Cisco PoE switches. We are running LRR with Actility software. Intermittently, any LoraWAN GW may l...
I seem to be running into issues with the configuration register working properly on the IE-3200-8P2S switches. I often use a USB stick to transfer images to the switch for staging, but if I leave the USB stick connected during boot, the switch will ...
Unanswered Topics
Top Solution Authors
