Hi everybody,
I'm completely stuck on found a solution for this problem.
I need to extend a VLAN over a connection between 2 IR1101 through cellular interface.
The problem is that any kind of tunnel or feature as Xconnect pseudo wire need to specify IP address instead a FQDN (that I manage every time with a DDNS service, that provide the right IP address anytime that change)
Actually interface tunnel like GRE support the destination with FQDN, and even if stamp in the configuration the IP temp address, with an recursive EEM Script I change the command when it need. And this should be good, but Tunnel GRE doesn't support IRB, or bridge-group.
So I look for the L2tpv3 solution, but Xconnect support just IP address and no hostname.
nobody of you, have got this Amletic problem?
Summary
vlan----IR1101--cellular lte---------------------cellular lte-----IR1101----same vlan to bridge
Thanks a lot for your interest
Maurizio
