I can't connect to a Cisco IR510 WPAN Gateway's console port (Console port (RJ45)).
I am using an Asunflower 6Ft Ftdi USB to Serial / Rs232 Console Rollover Cable for Cisco Routers - Rj45 cable.
I follow documentation https://www.cisco.com/c/en/us/td/docs/routers/ir510-ir530/hig/ir5X0_wpan_HIG.html.
But nothing.
How can I manage my hardware?
Solved! Go to Solution.
Hi Olivier ,
The IR510 does not have a CLI interface . you can use the CSMP gui tool for mgmt. pls reach out to me - nipjain@cisco.com for any further information and guides
thx-
Hi Olivier ,
thx-
