IE3300
rolando-munoz
IE3300 Switch will not boot after cycling power on it. I would appreciate some guidance on this issue. I tried talking to it through putty to trouble shoot. I had no break through and I also tried downloading an up date it seems to just be locked. I am unable to rest the switch for a hard reset as well.
Leo Laohoo
Console into the switch and reboot.
Post the entire boot-up process.
Leo, what command do I use to reboot? I have tried several commands, and I was unable to.
Use the reload command from enable mode.
Or power off/power on the switch.
Regards, LG
*** Please Rate All Helpful Responses ***
Kill the power to the switch.
Wait 5 seconds and energize.
