10-09-2020 10:21 AM
I am currently looking at buying the IR1101 Base Unit then attaching the IRM-1100-SPMI which allows an MSata to be installed. Currently I can only find the following for the expansion module:
Highlights of the mSATA Pluggable Module are: Provides an additional 100GB of additional flash memory storage
Does this mean it will only take 100gb or that the Cisco MSata of 100gb is supported only?
I really would like to know if I can buy another vendor MSata of the same physical size and install it.
10-09-2020 09:33 PM
Cisco mSata of 100gb ((IR1101-SSD-100G) is supported on IR1101. We don't support third party mSATA on IR1101.
10-12-2020 05:49 AM
Thanks for the response. Are third party drives just not supported and potentially work or is it locked down to your drives only?
10-12-2020 09:23 PM
IR1101 is locked down to Cisco hardware.
10-14-2020 10:02 AM
Any chance they will be coming out with bundled SKU's in the future that do not have the SSD almost eclipsing the cost of the router itself?
