question about IE5000 and VRF
Joseluisvg
Hello
In case someone has already made this configuration, it is possible to create VRFs on an IE5000 with Key LAN Base Software?
In the device datasheet, it indicates that for VRF-lite functionality IP services license is required.
But the switch gives the option to configure differents vrfs with software base lan, without license. But I wanted to be sure before moving the switch to production
cgonzale
Hi. Need IP Services for functional support (e.g. need to enable IP routing, etc.)
Hi. Thanks for the reply.
But I can enable ip routing and static routing with LAN Base Software. Effectively for dynamic routing or HSRP I need IP services license.
Also I have been able to activate and configure VRF in LAN Base Software. And for this, it is my doubt.
