Upgrade IE-3300-8P2S-E
gjoseph2140
Can a IE-3300-8P2S-E be upgraded a IE-3300-8P2S-A
@gjoseph2140
 considering the -E is Essencial license and -A is Advantage license, then, yes, you can upgrade those license.
A.  Cisco Catalyst IE3x00 Rugged support Cisco Smart Licensing. They support the following licenses:
●      Network Essentials (-E), which is available by default and is similar to LAN Base on the IE4000. This is a Layer 2 feature set. Network Essentials is perpetual, meaning it doesn’t expire.
●      Network Advantage (-A) is perpetual. This is similar to IP Services on the IE4000. This is the Layer 3 feature set that includes dynamic routing. It can be upgraded from -E or ordered directly on Cisco Commerce Workspace (CCW). To order on CCW will require details of the customer’s Smart Account.
●      Cisco DNA Essentials – This is an add-on subscription license for Cisco Catalyst Center basic management, in either 3, 5, or 7 year terms.
●      Cisco DNA Advantage – This is an add-on subscription license for Cisco Catalyst Center Software-Defined Access (SD-Access) Extended Nodes. It is also available in either 3, 5, or 7 year terms. The Network Advantage License is required on the IE switch for Cisco DNA Advantage license.
@gjoseph2140
Hello @gjoseph2140 ,
the two part numbers, IE-3300-8P2S-E and IE-3300-8P2S-A, point to the same hardware - IE-3300-8P2S. The two part numbers differ by the license they are ordered with:
IE-3300-8P2S-E - comes with Network Essentials license
IE-3300-8P2S-A - comes with Network Advantage license
Both part numbers can be upgraded with the same software file, for example ie3x00-universalk9.17.12.04.SPA.bin.
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
gjoseph2140
Thanks for the help. It is greatly appreciated.
