CISCO ISE 2 NETWORK ELEMENT SAME IP RADIUS
Greetings! i have a problem, i got hosted 2 different app in the same server . When i want to create second network device  i got this error. Is there anyway to archive with network device with same IP? It is same vendor.
Thank you in advance.
omz
You can have a look at this doc for editing/deleting a network device. Its an old doc but may help.
https://www.cisco.com/en/US/docs/security/ise/1.0/user_guide/ise10_man_network_devices.html#wp1053234
It does say -
–You can define a specific IP address, or a range with a subnet mask.
–You cannot define two devices with the same specific IP addresses.
–You cannot define two devices with the same IP range. The IP ranges must not overlap either partially or completely.
Hope this helps ... until someone can give you a more specific answer
omz
It does say -
Al'right.. Thank you.
