Hello
I have ACS version 5.5.0.46
I wan to schedule some backups, but ...
6 [28164]:[info] transfer: cars_xfer.c[333] [admin]: sftp copy out of /var/tmp/ADElogs.tar.gz requested
6 [28164]:[info] transfer: cars_xfer_util.c[581] [admin]: resolved server to 10.1.1.1
7 [28164]:[debug] transfer: sftp_handler.c[859] [admin]: Running sftp command: 10.1.1.1 acsbackup *** //ADElogs.tar.gz put /var/tmp/ADElogs.tar.gz //ADElogs.tar.gz
7 [28172]:[debug] transfer: sftp_handler.c[165] [system]: Executing SFTP command: /usr/bin/sftp acsbackup@10.1.1.1
3 [28164]:[error] transfer: sftp_handler.c[254] [admin]: sftp_read Error: read failed
3 [28164]:[error] transfer: sftp_handler.c[533] [admin]: sftp_run_parent Error: read(comand prompt) failed
7 [28164]:[debug] transfer: sftp_handler.c[675] [admin]: sftp parent status -306
/admin# backup acsbackup repository myrepo
% backup in progress: Starting Backup...10% completed
% Creating backup with timestamped filename: acsbackup-141105-1025.tar.gpg
Please enter backup encryption password [8-32 chars]:
Please enter the password again:
% backup in progress: Backing up ADEOS configuration...55% completed
Calculating disk size for /opt/backup/backup-acsbackup-1415183129
Total size of backup files are 693 M.
Max Size defined for backup files are 36102 M.
% backup in progress: Moving Backup file to the repository...75% completed
% SSH connect error
What is the problem, bug ?
