Adapters for Cisco Process Orchestrator
bbalasateesh
Community Member
Hi All,
I want the steps on integration of Cisco Process Orchestration with Openstack. Are there any available adapters for this process. If not can anyone explain on steps to write the custom adapters for integration with Openstack.
Thanks in advance,
Sateesh B.
Shaun Roberts
We currently do not allow writing of custom adapters. We can integrate through many components through multiple means including adapters, CLIs, web services, XMLs, etc.
You should be able to look at your install of CPO and see all the current adapters or refer to your CPO documentation.
If you are a customer and want more information please open a TAC case.
thanks,
Shaun Roberts
CPO/CIAC Support Team Lead
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
