Add timestamp using variable
Bill Slobodnik
Date stamp was easy to create using a custom format variable, but I cannot see how to do the same for a time stamp.  I would need a time stamp format without colons or slashes that would be rejected as a filename.
Can a custom format Time variable be created?  Or has anyone created a job which adds timestamps to files?   I can script it of course, but looking for a clean all purpose time stamp process.
thanks
Marc Clasby
For a file stamp the tidal system date is easy solution (you can use any date type variable)
Tidal Variables
Use system time (typically you add via variable button)
Take and remove :
and you will just get the numbers
use that as a tag to job
if you use Powershell you could use the get-date function as well depending ans format it depending on what you want to do.i
Marc
Marc Clasby
Tidal Variables
Take and remove :
Marc
Thanks Marc.   I did not realize I could actually edit the variable format once it was added to the job.  Too easy!
Thanks Marc!!! I owe you a beer
