basic questions about CPO
MarekW123
Beginner
Beginner
I just wondering about Cisco process Orchestrator and I have several questions about this product.
1) How many workflow can run at the same time in Cisco Process Orchestartor ?
2) Can i make the groups in CPO (each group has own settings)?
3) Can i copy policies from my Active Directory to CPO?
4) How long does it take instalation and integration of CPO to a new enviroment?
Thank you
Marek
Shaun Roberts
1) There is no limit currently.
2) If you mean security groups, then yes
3) Depends, how do you do that normally/what's the use case?
4) I can install CPO (if machines already in place) in 10-15 minutes. If you throw target setup and configuration in there, maybe 45 minutes max, again all depends on the deployment
If you have more specific questions, please open a TAC case with your support contract.
thanks,
Shaun Roberts
CIAC/CPO Support Team Lead
shaurobe@cisco.com
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
Recognize Your Peers
