02-28-2014 11:27 AM - edited 03-01-2019 09:07 AM
TES Version: 6.0.3.260
Currently my TES is only set up for one domain, is there a way to configure it for multiple domains so I can add other users?
Solved! Go to Solution.
03-03-2014 08:49 AM
You can have one domain per CM, so adding more CMs will get you more domains to authenticate against. You can set up LDAP groups within this one domain, but that is it.
Multiple domain support per CM instance is a feature that will be added in 6.2 of the product, scheduled to come out in a few months.
03-03-2014 08:49 AM
05-19-2016 07:43 AM
6.2.1 has multi domain support. You can have multiple domains per CM, instead of only one.
