CPO 2.3.4 & Powershell 3.0
Rishikesh Radhakrishnan
Has anyone faced compatibility issues between CPO 2.3.4 and Powershell v 3.0 ?
Rishikesh R.
Shaun Roberts
In the shelf report it shows we added support for PS v 3.0 in CPO 2.3.4. So it should work fine. If you have any issues I would suggest opening a TAC case.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
Oh ok, I haven't tested it yet, just wanted to check before upgrading any components.
Rishikesh R.
Von Jones
Level 4
Level 4
Is this an IAC deployment?  Is your question about PO compatibility or IAC content compatibility?
This was about PO compatibility.
Rishikesh R.
