CPSC 11.0 requirement
romaingautier
I read CPSC 11.0 requires Red Hat Enterprise Linux Server 7.0 from the Compatibility Matrix.
Is is possible to run on a Red Hat Entreprise Linux Server 6.2 or 6.4 instead?
mpetra
Slow response.... Yes PSC will run without any problems. Just remember the compatibility matrix lists officially supported platforms. Earlier (or later) versions of RHEL would not be supported by TAC.
Typically only the database requirements are strict and have enforcement checks to stop the installer. For Operating Systems, many other versions work, but the compatibility matrix is really just a list of supported/tested platforms.
Thank you for your relieving answer ;) !
