CSCvh14751 - Java Client - cannot see 12/31/2017 in job activity for MSSQL DB Environment
Kenneth Kuchynka
All,
     We have discovered a display issue that only affects the Java Client and is only a display issue and does not occur in the Client Manager's Web Client.  We are working on resolving the issue as soon as possible.
Symptom
Job activity for 12/31/2017 is blank for Java Client connecting to a MSSQL DB environment
Environment Conditions
Master \ Java Client Versions Affected
6.2.1
6.3.x
Master database on MSSQL
Workaround
Use Web Client
Maximilian Gallagher
Update:
This has been resolved in build 6.2.1.776 and 6.3.1.97 in the MASTER builds. You cannot only patch the java client to receive this fix. These builds have passed QA and have been included in the December rollups, linked here. Be sure to use the hotfix relative to your version (6.2.1 vs 6.3.1).
6.2.1:
https://software.cisco.com/download/release.html?mdfid=286266581&catid=286304602&softwareid=283781148&release=6.2.1&relind=AVAILABLE&rellifecycle=&reltype=latest
6.3.1:
https://software.cisco.com/download/release.html?mdfid=283340354&softwareid=283781148&release=6.3.1&relind=AVAILABLE&rellifecycle=&reltype=latest
Issue was discovered with Dec Patch Roll up.
Issue
CSCvh30237 M - cannot mark completed jobs on prior days
We apologize for the inconvenience and have pulled the Dec Roll up and will be replacing with a new roll up once the discovered problem has been addressed.
Update:
This issue has been resolved in build 6.2.1.782 and 6.3.1.98 in the MASTER builds. These builds have passed QA and have been included in the new December rollups, PFB links below.
6.2.1:
6.3.1:
