Feature request(s)
Marc Clasby
I am not sure if this is appropriate in this area, but I am also curious about what other features other customers are interested in, here are a few of ours:
  1. Email Adapter to have the ability to strip off an attachment to an email that is sent to a tidal email box and save to a network path (with variables) and the ability to save as a different file name
  2. Email Adapter to have the ability to delete / archive emails (to automate email maintenance)
  3. Email Adapter to have the ability to use variables (global, group) on scan for text in message/subject
  4. Tidal FTP MGET function, remove the directory listings prior to MGET (built into code) it will bomb out on FTP repositories with large amout of files
  5. Calendar offset to be able to exceed 31 days
  6. Calendar object be able to offset incremental days so that you could make a calendar "every 80 days" exactly
  7. Ability to group Resource (like an agent list, for easier view)
  8. Ability to group Variables (like an agent list, for easier view)
  9. Ability to group Variables (like an agent list, for easier view)
Marc
John Laird
Please submit the enhancement requests to support by opening a case for each request (keep them seperate). Be sure to put in your email description that this is a enhancement request.
John
-Tidal TAC
