Fix for javascript errors in OrganizationDesigner and other places
Blaine Lincoln
A sequence of DLL/Control re-registration to clear up javascript errors in all the OrganizationDesigner popups.
I had a lot of problems with javascript errors in Org Designer.  I was able to fix them by re-registering some IE controls and libraries.  In doing so I have cleared up all my javascript errors.  Here is the sequence - hopefully it helps others.
open a command window and type the following:
regsvr32 msscript.ocx
regsvr32 dispex.dll
regsvr32 vbscript.dll
Ant Erickson
Hi Blaine,
This will also fix some errors you might see when a customer clicks on a calendar date/time field and the calendar shows up blank.  Was difficult to diagnose it but found unrelated articles on the internet.  Thanks for posting here and saving many people the time.
Ant
