how to cretae batch file to run sacmd through c# application
hi guys ,
 i want to create a batch file to run sacmd command prompt from c# application  , is this possible create batch file to run sacmd
please anyone  help me
Yes, certainly. Refer to commandline guide provided with the product. You should have all the information inside that
dinesh ,
i'm new to the cisco tidal , i gone through the command line guide but i doesn't fine how to write bat file and run using c# , will please send me one example for that
thanks in advance
There are two parts to this.
  1. To create a batch script to run sacmd.
    • Make sure you have installed TESCommandLine on your Tidal environment
    • Then make sure you have activated the CommandLine, as given in the guide. You should also see how you can save the user credentials using -persist option in the user guide. The below example assumes the credentials are saved. If not you have to use -pass parameter for the user's password
    • Create batch script. Sample for getting job alias for a given job name.
      • ::listrule +i ->It is used the get the job ID. '+i' will contain the output.
        ::-n ->Here we pass the job name for which we need Job ID.
        :: %1 -> Job Name
        :: %2 -> URL to invoke sacmd scripts. Generally points to CM. It's different than the CM URL
        :: %3 -> User name
        cd C:\Program Files\TIDAL\TESCmdLine\bin\
        sacmd -cmdspurl %2 -user domain\%3 listrule +i -n %1
  2. How to call the batch script from C#.
For this, you will need to refer to MSDN or other forums like stackoverflow. There are several examples on the web. For example, http://stackoverflow.com/questions/5519328/executing-batch-file-in-c-sharp
- Dinesh
