We are trying to automate the export of job group/job definition from tidal in xml file, we know that you can use REST API to get job definition as xml.
by using http://localhost:8080/api/tes-6.0/Job.get/<Job ID/alias>
but the problem is when you use it for group it does not tell you what are all the child of this job group.
here is the output you get from REST API
<entry><id>354</id><title>TestJOb</title><source>com.tidalsoft.webclient.tes.dsp.db.datatypes.Job</source><tes:job><tes:agenttype>6</tes:agenttype><tes:childrencount>6</tes:childrencount><tes:agentostype>1</tes:agentostype><tes:ownername>IDX_Workgroup</tes:ownername><tes:agentname>machinename</tes:agentname><tes:parentname>\Test</tes:parentname><tes:rerundependency>N</tes:rerundependency><tes:dependencylogic>1</tes:dependencylogic><tes:durationminimum>60</tes:durationminimum><tes:parentactive>Y</tes:parentactive><tes:unixprofile>0</tes:unixprofile><tes:type>1</tes:type><tes:normalexittorange>0</tes:normalexittorange><tes:estimatedmethod>1</tes:estimatedmethod><tes:predecessorsvalue>N</tes:predecessorsvalue><tes:isnotes>false</tes:isnotes><tes:historyretention>30</tes:historyretention><tes:jobdetailid>354</tes:jobdetailid><tes:durationestimated>60</tes:durationestimated><tes:trackingmethod>1</tes:trackingmethod><tes:active>Y</tes:active><tes:durationmaximum>60</tes:durationmaximum><tes:repeat/><tes:id>354</tes:id><tes:dirty> </tes:dirty><tes:ownerid>13</tes:ownerid><tes:fullpath>\Test\TestJOb</tes:fullpath><tes:concurrency>3</tes:concurrency><tes:isrunbook>false</tes:isrunbook><tes:excludeabnormalduration>4</tes:excludeabnormalduration><tes:inheritrepeat>Y</tes:inheritrepeat><tes:inheritoptions>Y</tes:inheritoptions><tes:disablecarryover>1</tes:disablecarryover><tes:normalexitfromrange>0</tes:normalexitfromrange><tes:successorsvalue>N</tes:successorsvalue><tes:inherittimewindow>N</tes:inherittimewindow><tes:lastusermodifiedtime>2013-05-13T00:47:30-0700</tes:lastusermodifiedtime><tes:allowrerun>Y</tes:allowrerun><tes:parentid>18</tes:parentid><tes:agentid>2</tes:agentid><tes:priority>50</tes:priority><tes:inheritagent>N</tes:inheritagent><tes:name>IDX.TestWebService</tes:name><tes:nearoutage>3</tes:nearoutage><tes:saveoutputoption>Y</tes:saveoutputoption><tes:alias>354</tes:alias><tes:allowunscheduled>Y</tes:allowunscheduled><tes:createtime>2013-05-12T23:32:05-0700</tes:createtime><tes:inheritcalendar>N</tes:inheritcalendar><tes:waitOperator>N</tes:waitOperator><tes:exitcodenormaloperator>1</tes:exitcodenormaloperator><tes:lastchangetime>2013-05-13T00:47:30-0700</tes:lastchangetime><tes:clientcachelastchangetime>2013-05-13T00:47:30-0700</tes:clientcachelastchangetime></tes:job></entry>
it gives you number of child in the group, but does not give further info like what are the JOb ID/alias of children.
we need this information to dynamically get job definition of all the jobs within a job group.
Any help much appreacited.
