Java Client through citrix
Joe Fletcher
Anyone tried running the TES 6.2.1 java client through citrix? We just installed it and it worked briefly. Now any new connection just sits there saying "Connecting to server". Bouncing the server (either end) doesn't help.
I'm guessing it might be a citrix problem as local desktop installs work fine. TES java client is v 6.2.1.236, host is Windows Server 2008 R2 Standard 64bit under VMware, jdk 1.7.0_79.
Anyone know of any citrix tweaks that might be applicable for an 8Gb java app?
Cheers
Joe Fletcher
Looks like we have a fix for this. Seems there's a problem with the Citrix THEMES service. Disabling this allows the client to function normally.
