08-27-2015 02:30 PM - edited 03-01-2019 09:16 AM
Hi Team, Iam a newbie to using this tool and am in the process of evaluating it to understand if it can support some of my current challenges in Autosys which is
Can you please help me understand if all these issues can be solved using Tidal?
Lavanya
09-10-2015 10:36 AM
Hi Lavanya - Don't know if I am too late in responding. I have a very little experience with Autosys and didn't like it.
You can generate reports that show what a particular person has manually performed in Tidal. It isn't a canned report, but can be done.
Tidal definitely has an intelligent alerting system. Alerts can be sent to the console, to email, to snmp. They can be sent based on specific statuses of the job. So if one day the job fails with 'error occurred' you could have it send an email. If the job is rerun and fails with 'completed abnormally' you could have an snmp alert triggered.
As far as delayed start, I am guessing you mean that if the job is scheduled for the 10th minute, that it launches at the 10th minute. Yes, Tidal does this once all of the dependencies are met. (Dependencies in Tidal are the jobs running first in the stream, not the jobs following).
Statuses are reported quickly as well. If there is a large amount of output that is being sent back to Tidal, you might see a delay. It also depends on how often you have your client refresh the status.
Hope this helps,
Michelle
09-10-2015 03:21 PM
Lavanya
I agree with Michelle
09-16-2015 03:20 PM
Thank you Michelle..This helps.
