Power down and Power savor options are not working properly
ynoor
Hello IAC Friends,
I'm have installed a VM by ordering the server from portal. VM installed successfully.
I have shutdown the VM(physically) and tried to power up the VM and the VM got powered up with out any issue
When I try with Powerdown/Power saver I'm hitting with an issue as follows:
Can any one suggest me on this.
thanks,
noor
mpavlish
Hi Noor,
Are you seeing any Java Script error on the page? On IE it would be shown as yellow triangle in your browser bottom left corner.
Regardless, it might be a good idea to raise this as new ticket with TAC.
Max.
Than's for the giving update Max..
I have raised a Tac case on this I got an hotfix for this..
9.3.2_HotFix_MandatoryCheckBox_v02
I'm checking with this patch..
