12-03-2015 11:56 AM - edited 03-01-2019 09:19 AM
I have a job were the p10 step recurs every 15 minutes. I have a p20 that is set to run at 11:45 am. It is set to check for completed normally on last occurance of P10. I have a P30 that runs at 1:45 that also checks for completed normally on last occurance of p10. My issue is P20, 30 cannot run until P10 is done. I cannot set a dependancy to check for <> active and completed normally.
Job function:
P10 provides most current data for P20& p30's time dependant report.
Suggestions?
Version 6.2.1.236
Solved! Go to Solution.
12-03-2015 01:38 PM
Hi hrechek4470,
Sounds like you are on the right track. OK to keep the current setup the same. But here we will add a variable dependency instead.
Step 1. Create and initialize variable to false, ie, P10_Ready := False
Step 2. Create a variable action to set P10_Ready := True
Step 3. Create a variable action to set P10_Ready := False
Step 4. Create a job event when job completes normally, call variable action to set P10_Ready to True (Step 2)
Step 5. Create a job event when job is active, call variable action to set P10_Ready back to False (Step 3)
Step 6. Add variable dependency when P10_Ready = True to both P20 and P30 jobs
BR,
Derrick Au
12-03-2015 01:38 PM
Hi hrechek4470,
BR,
Derrick Au
