Highlighted
Beginner
Regarding Calendar Expiry in Tidal Enterprise Scheduler
Hi All,
While checking the Tidal Admiral DB i found that the Table evntmst contains a column evntmst_untildt which contains information about the Last possible calendar date to include. If the date mentioned is 31st DEC 2013 does it means after this date the Calendar will get expire? if so how to change the expiration date.
Thanks.
Parul.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Highlighted
Beginner
The data model says that field is Last possible calendar date to include
Looking at our dates in our database I would say that that field isn't used for either calculation or expiraiton.
I think Cisco TAC would have to comment further, but if I were to bet... I would say that it was obsoleted...
I just created a calendar in our dev environment and heres what I found:
evntmst_untildt        <--- looks like this stores the calculated date 3 years out to the end of that year
2016-12-31 00:00:00.000
evntmst_lstcmptm   <-- last Last time dates for this calendar were compiled
2013-09-11 11:43:50.000
if Calendars did expire it would create huge operational headaches..
How would you even know what the value is as I don't think that field is exposed through the GUI
From a best practices/maintenance perspective
We calculate all our calendards annually in december to project out the date 3 years
Marc
3 REPLIES 3
Highlighted
Beginner
You should recalculate your calendars ...you can do this manually of with an API
right click - re-calculate (or update dates if it is a list calendar)
This should calculate for the current year and the next three years.
try one of the default ones first in a dev environment to see the behavior.
Marc
Highlighted
Beginner
Thanks for your response Marc, The forcasted date if differing from the untill date I am not sure if this is an expected behavior? I will try recalculating the date so does that mean we need to monitore the untill date and planned an activity to recalculate the calander?
Parul
Highlighted
Beginner
Marc
Content for Community-Ad
Cisco COVID-19 Survey
