05-08-2012 01:32 PM
I installed the SSL Certificates on the windows machine where our CPO server is configured. And I also configured the web service adapter to use secured authentication on the default port.
Is there anything else I would need to configure other than the above inorder to have the SSL connectivity? Also are there any standard tests I can perform from CPO inorder to validate this configuration.
Greg
Solved! Go to Solution.
05-08-2012 01:42 PM
You need to make sure you have followed all the steps on page 12 of the Northbound Web Services guide. If you have you can test by opening a browser and going to https://
You can test with portal feeding information in or you can run web service executes (in CPO) against it to further test.
05-08-2012 01:42 PM
05-16-2012 06:34 AM
Thanks Chris.
I installed the certificates as mentioned in the guide. Along with that, I had to edit the binding settings seperately for CPO webconsole and CPO Monitoring under IIS. Now the CPO webconsole can also be accessed using https in our environment.
Greg
05-16-2012 11:10 AM
One final question about this:
If I have the CPO webconsole installed on a different host than the CPO server, is there a need to install seperate certificate on the host where CPO webconsole is present?
Greg
