TES6.1 Load Balancing and DSP
Haven't gotten much response to my other posts, hoping I get some about this.
For those using load balancing, do you name your DSP the same on both servers?  I was trying to see if there were pros and cons to naming them different or the same (or if you can't name them the same).
We have them named different, one is TesDevCM1 and the other is TesDevCM2.  This makes it easier to troubleshoot and know where someone is connected BUT I realize that this is not good when you are trying to truly utilize loadbalancing for example for Transporter and TESCmmandline as this forces you to bound these apps to a specific CM.
Just wanted to see if there were opinions out there. (Made my post shorter, hopefully someone will respond ^_^)
Everyone's tags (5)
