04-13-2016 07:46 AM - edited 03-01-2019 09:21 AM
When our admin attempts to migrate/move the job to Prod tier from QA using transporter it throws an error.
Job \QA\Apps Office Auto A\Statewide Emergency Event Resource Tracking\STICC in action Call SEERT STICC Job does not exist in the destination database.
The action job "Call SEERT STICC Job" exist in QA. The job "STICC" that the job action calls also exists. There was no problem moving the job from Test to QA using the same transporter tool. However, to move the job to QA to Prod it throws there error.
I attached the screen shot of the error, job action, and the job on the file "transporterissue.doc". please advise.
tidal master 5.3.1.373
thank you,
warren
04-13-2016 01:19 PM
Hi Warren,
In short the correct sequence for migration from QA to PROD is
1) STICC job, then
2) Job Action, Call SEERT STICC Job
and not the other way around.
BR,
Derrick Au
04-14-2016 05:04 AM
thanks derrick. right the STICC job was migrated first. then the job action was right after the STICC job. this was when the transporter throws an error.
04-14-2016 11:38 AM
Hi Warren,
That's odd. Can you please confirm if STICC and its children jobs migrated successfully? If succeeded, then the action should be able to migrate over. The transporter should also have some logs that might offer more clues as to what might have triggered that error message. Also, the Master and Transporter version that you are on is a bit outdated, you may be required to patch.
BR,
Derrick Au
