Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
602
Highlighted
Beginner
AIP-SSM20:Can't change password -- Please help
I reset the password using  hw-module command.  But now I can't change the default password of  cisco.  it is rejecting any password combination i tried, uppercase,  lower case, numbers, and non-alphanumerics.  It is probably the password  requrement policy I put in before.  How can I get around this or  restore default confiration?
thank you.
login: cisco
Password:
You are required to change your password immediately (password aged)
Changing password for cisco
(current) password:
New password:
BAD PASSWORD: is too simple
New password:
New password:
Mod Card Type                                    Model              Serial No.
  1 ASA 5500 Series Security Services Module-20  ASA-SSM-20         JAF1204AQHT
Mod MAC Address Range                 Hw Version   Fw Version   Sw Version
  1 001e.7a36.7aba to 001e.7a36.7aba  1.0          1.0(11)2     7.0(5a)E4
Mod SSM Application Name           Status           SSM Application Version
  1 IPS                            Up               7.0(5a)E4
Mod Status             Data Plane Status     Compatibility
  1 Up                 Up
1 ACCEPTED SOLUTION
hi ,
can you try a more complex password .
cheers 1
2 REPLIES 2
hi ,
cheers 1
Beginner
I got it.  It took a 24 character long complex passowrd.  When Ifinelly got in, I checked password requirement . All the settings were to the defaults. it suprise me quite.
thank you Mohammad.
