11-15-2009 09:12 PM - edited 03-10-2019 04:49 AM
Analysis Engine is not running and giving Error:
Error: getAnalysisEngineStatistics : ct-sensorApp.598 not responding, please check system processes - The connect to the specified Io::ClientPipe failed
11-16-2009 11:00 AM
Reboot your IDSM, if you have not done so already. From the router CLI:
hw-module reset X reset (X is the slot number for your IDSM)
This happens after some software upgrades and (fewer) signature updates.
11-24-2009 08:26 PM
Thanks for your respanse,I have restarted the module and after few days we are getting same error.we are using Intrusion Prevention System, Version 6.2(1)E3. for last one and half years.Is there any bug issue related to this.
11-25-2009 03:55 AM
I fixed this issue once using the following procedure:
https://supportforums.cisco.com/docs/DOC-3589
If the above procedure or reload does not fix the issue as suggested on the following link:
You have to contact TAC, as mentioned below:
http://www.cisco.com/en/US/docs/security/ips/6.0/installation/guide/hwTS.html#wp1122031
Farrukh
Message was edited by: Farrukh Haroon
