04-08-2016 11:00 AM - edited 03-10-2019 06:35 AM
We have an ASA 5515-X and recently purchased the Firesight IPS Module. I was wondering if anyone had recommendations for a Dell Server Setup to run ESXi for the OVA. Ex: RAM, Processor...ETC.
04-08-2016 09:23 PM
The server hardware model isn't critical.
As long as you meet the minimums it will work OK. ( 8 GB RAM (as of version 6.0), 4 vCPUs and 250 GB storage)
More RAM allocated to the VM always helps. More storage will just allow you to archive more events. The system isn't typically CPU-bound so that isn't as material.
04-23-2016 04:59 AM
8 GB RAM is decent enough for the VM's to perform well . Afterall its based on the events that gets stored on the device . If you need to store more events give it more resources. While installation please use thin provision . Storing more events without enough resources will affect the device performance and it may also cause latency.
