ASA 5520 IPS with ASA 5540
aryarahul
I have an ASA 5540 F/W and a ASA 5520 IPS with AIP-SSM 20.
Rite now ASA 5540 is conected with the internet Router on the outside interface , there is an inside zone and a DMZ zone as well.
My Question is where shud i put IPS?
1_ Between the internet router and the ASA 5540
2_ or in the inside zone ?
If i were to put it in between the outside zone i.e between ASA 5540 Outside and the internet router then do i require separate WAN ips for the inside and outside of IPS ?? currently as required ASA 5540 outside has been configured a WAN ip
Please help
8 Replies 8
sawgupta
It depends on your requirement. However configuration should be like "Internet Router <--> ASA 5540 <--> IPS"
Sawan Gupta
Thanks & Regards, Sawan Gupta
Thanks for the reply ..
so if i were to put it as Internet Router -- ASA 5540 --ASA 5520 (IPS) then shud IPS be put in the DMZ zone ??or the Inside zone ..i guess it shud b in the DMZ zone ...in that case it will be assigned a LAN ip on both interfaces.?
anybdy ??
I am not sure I understand your requirement for the second ASA.  You could just install the SSM-20 into the 5540 and choose to inspect traffic either globally (all interfaces) or on a subset of interfaces.
hi please i want to ask a question about the ASA IPS Password
i lost my ASA IPS PASSWORD what to do?
Try this command from the ASA's CLI.
"hw-module module 1 password-reset"
thanks for your reply
but what about the existing configuration or this command will not effect the configuration
if IPS is to be installed along with a separate ASA then what shud be the architecture
i have 2 ASA 5540 configured as Cluster and a Separate ASA IPS 5520
where shud i put the ASA 5520 ???
